Brackle
Old Timer
- Jun 19, 2003
http://www.pcper.com/news/Graphics-...raw-Increased-Refresh-Rates-using-ASUS-PG279Q
Wow.....that is some crazy ass shit!
I thought this was common knowledge? It happens(happened?) when running monitors in eyefinity/surround too.
I thought so, too . NVIDIA have stated that they put the video card into a high power state to prevent issues when running at high refresh rates or multiple monitors, including lockups, flashing, and loss of signal. I heard that AMD tried to introduce a low power state for these configurations, but they experience these very issues NVIDIA describes.I thought this was common knowledge? It happens(happened?) when running monitors in eyefinity/surround too.
I just run my desktop at 120 Hz and fullscreen games at 144 Hz using the "Highest available" option for refresh rate in the NVCP.
Problem solved.
/thread
Oh no, 27 watts? My budget!
That's 2 take out meals. Hardly adds up to much of anything.
You could say the same thing about AMD Cards. People bitch about power usage. Now people are saying added power from this isn't a big deal. But it is if its AMD's power we are talking about.
We're talking peak power versus higher idle power. Peak means you MAY need better PSU / case / watercooler to handle the increased load during a game, and that's not so cheap.
The difference is even more pronounced if you're running two cards, or if you're a fan of silence. That "great deal" you got could cost you more when you look at the supporting cast you need to remove that extra heat.
dont you think you would use more power every month if your PC is idle and using 200w. over using 100w more while gaming?
Your PC's idles way more then being at 100% for gaming. So in a sense you would pay more for electricity if you idle at 200w over 41w. SPECIALLY since you idle your pc more then you game.
120 vs 144hz can you even tell the difference? I'm asking people who've actually owned both.
If I can save money doing something simple as downclocking my GPUs when idle then why not? Also I turn off my lights when I leave the house and make my own lunches for work!
It's not a case of your load power becoming your idle power, it's a case of your idle power increasing 60w. If my load power was 60w over my idle power, I would jump up and down with joy (as I'm sure many other [H]'ers would).
I like how the autor of the article sound like a child discovering new disneyland.. but also suggesting crazy ancient things like separated engine clock and shader clocks... =D so are we going to return to Pixel Clock and Shader clock no more unified shader what's next? separated Pixel, Vertex and geometry shaders? what a stupid commentary IMO.
That "issue" is happening since the introduction of high refresh panels 1920x1080@144hz, or multi monitor setups as NickJames Said, but even not only in eyefinity/surround. AMD somewhat fixed it with Hawaii the 290 and 290X were able to stay at 144hz single monitor without trigger 3D clocks, however you can't run more than single 1080P panel or it will be at full 3D clocks, however with nvidia you can run 3x 1080P monitors without trigger 3D clocks, but that's the limit once you start to mix things with 1440P, 1080P or 4K it will be always at 3D clocks..
^This..
No, not really.Wow.....that is some crazy ass shit!
Dumb question from a 60Hz display owner: can you set separate refresh rates on your monitor for gaming and desktop use? I would not be happy with my card at full clocks at desktop, not from the power usage as much as the heat and related fan noise.
Weird I have a 144hz monitor and have that set as my refresh and my card down-clocks to 135mhz on the desktop just fine. I monitored it with gpu-z and afterburner.
Using the latest gsync "hot fix" beta drivers.
http://i.picpar.com/XR8b.png[/im][/QUOTE]
Resolution matters. Is yours 1440p?
