PCP&C 610W & Power calculators
rampantandroid
Hello All,
I was recently poking around at previews of the ATI/AMD 4870X2, and wondered if my 610W PSU could potentially handle it (yes, I know - no hard info yet) so I checked out the "eXtreme Power Supply Calculator" and put in my specs:
Q6600 B3, eVGA 680i SLI, 8800 GTS 512MB, X-Fi Platinum, 2 DVD-RW drives, 2x 150 GB WD Raptors, 1x Seagate 750 GB drive
Now, when I put all that in, the calculator says I need something like...700W, which can't be true, as my current system functions fine under full load. Would it be possible for it to handle a 4870X2, or should I also put a PCP&C 750W PSU into my budget? I suppose for those who are going to inevitably say no way to know, then to ask a more plausible question: is it possible for my setup to handle two 4870s in crossfire? I assume the 4870X2 will consume less power than two 4870s in CF....
Thanks!
Using the Corsair PSU Finder as reference, when I inputted your rig plus two HD4870 in Crossfire, the smallest PSU recommended was the Corsair 620HX which has 50A on the +12V rail. Your Silencer 610W has 49A on the +12V rail. Pretty close.
So your PSU should be able to handle two HD4870 in Crossfire just fine. BTW, the HD4870X2 actually uses 10W more than HD4870 CF (Don't forget that HD4870X2 has two GPUs):
http://hardocp.com/article.html?art=MTUzMSw5LCxoZW50aHVzaWFzdA==
I assumed it used less, as CF would be less efficient, and Anandtech says it uses less than 4870CF, I think.
Anyway, any idea of how close it is? Would I just be better off buying a new PSU, rather then grabbing a 4870X2 and seeing if it works? If I increase the number of drives I have by 2 (2 DVD-RW drives, and I figure the X-Fi is going to use a bit of power) it says I need the 750W PSU.
I think your fine. Worst comes to worst you kill the unit, buy a new one, RMA the PC P&C, and sell the RMA as NIB.
Here lets use some numbers: Hard OCP says a standard setup containing single HD4870X2 consumes 470W of power, lets round that up to 500W. at 80% efficiency that means the PSU is actually putting out just under 2/3rds of of its rated capacity. I think your fine.
Here lets use some numbers: Hard OCP says a single HD4870X2 consumes 470W of power, lets round that up to 500W. at 80% efficiency that means the PSU is actually putting out just under 2/3rds of of its rated capacity. I think your fine.
And add in a CPU using 100W?
