Got it directly from Ameri-Rack, as mentioned in my post![]()
I got that it was a part from Ameri-Rack, but Google says they don't deal with end users. Google also says opposite
I got that it was a part from Ameri-Rack, but Google says they don't deal with end users. Google also says oppositeJust wondered if you bought it from somewhere else like one would buy an Asus motherboard from Newegg and not directly from Asus. Anyways, how long is your riser? Do you find it to fit perfect or would you modify the length if you were to order a new one today?
OK thanksI guess 10cm is the right one for the A4. Guess I'll have to order a couple for future usage as I can't find anything else anywhere. Would hate to see them become unavailable in the future when I actually need it
But... it's all answered in my post...Anyways, how long is your riser? Do you find it to fit perfect or would you modify the length if you were to order a new one today? Are you able to boot from the nvme?
If you mean whether it'd fit instead of the bifurcatred one in an A4-SFX with a full-sized graphics card, then definitely not.Do you think a trifurbication riser could fit (8x+4x+4x), assuming the third socket is spaced evenly spaced as the bifurbication riser? (One might need a thinner cooler for a second NVME)
Email "sales@ameri-rack.com"
I had the subject as "Purchase/quote"
My email went like this:
I am interested in purchasing the "6) ARC1-PERY423-C20(reversed, w/20cm ribbon to face over the board)".
http://www.ameri-rack.com/ARC2-PELY423-C7_m.html
The shipping address and billing address is:
[My name]
[My Address]
Thank you,
[My name]
they should email you back and give you a link to an invoice you can pay and then they'll ship it to you and email you the tracking info.
Are there any ATX motherboards that support bifurcation? Hear me out on this one first...
I have a proposed build with a Cooler Master MasterCase5 using a vertical gpu mount that only allows a single GPU. Wanted to mount a dual GPU setup with EK blocks utilizing an EK FC Terminal Dual Single slot and an Ameritrack riser. Are the only motherboards that support this generally ASROCK? Anything from ASUS?
Are there any ATX motherboards that support bifurcation? Hear me out on this one first...![]()
I know this is the SFF forum, but I was wondering if anyone was able to mod the BIOS of a Supermicro motherboard? I've been trying to get this working on my X10DRL-CT but not getting anywhere. I changed the settings in AMIBCP and when I go to the BIOS, it shows 4x4x4x4 but when VMWare boots, it only sees 1 NVME. Just trying to see if anyone else has run into this.
From looking at the motherboard schematics in the user manual, it looks to be the correct one. Changed the setting in AMIBCP and then flipped a few bits using HxD and it shows up with the link speed for each port but then adding the card got me nothing. I reset the CMOS and nothing, so I'm diving to see if it was something that I missed. First time really getting into trying to mod a BIOS and it is taking some serious patience. Wish Supermicro just hooked me up with a beta BIOS.Two things come to my mind(maybe too obvious?): wrong IIO. Also did you do a full cmos reset after modding?
When I am back from vacation I will try to experiment some more with bios modding too...
I just remembered the guy that had success modding a bios for bifurcation.
Read:
https://www.win-raid.com/t3323f16-Guide-How-to-Bifurcate-a-PCI-E-slot.html
Oh how fun! My vote would be something like the Asus X470ITX (or X370). Its basicly the best AM4 ITX motherboard. I would choose it over the Z370 variant because the AM4 socket will still have a couple of new CPU generations supported on it. Bad thing is those are a bit pricey.Quick Poll: Anyone interested in bifurcation BIOS hax for a particular Mainboard? (preferably ITX and preferably a bit older) I am going to buy one or two boards for my hacking attempts to enable bifurcation on non supported MoBos.
Maybe someone has some unused hardware to sell/donate?!?
I would also be for the x470i.Quick Poll: Anyone interested in bifurcation BIOS hax for a particular Mainboard? (preferably ITX and preferably a bit older) I am going to buy one or two boards for my hacking attempts to enable bifurcation on non supported MoBos.
I'm thinking it could be done, but I'm also thinking you'd be wise to undervolt anything you can. Those Fury cards love power if you don't keep them on a leash.Hey I'm planning on doing a dual itx GPU build, similar to the MaximumBurrito 's dual r9 nano build. Could any one who is running two gpu's in an itx system let me know what wattage PSU they're using. I bought a SF600 gold and I don't planning on doing any water cooling or anything but I'm hoping that would be enough. Has anyone checked how much power they're pulling from a system with two itx gpu's?
Gamer's Nexus has an article on it: LinkAnyone been able to test NVLINK with bifurcation? I have not read any reviews comparing 8x PCIe 3.0 vs 16x with RTX series.
I've done some quick drafting in CAD to get a feeling at what kind of dimensions we are looking at.
If you stick to a SFX PSU, Silverstone has a 700W version coming, I can stay just shy of 10 liters, a little smaller. Rough dimensions would be 35cm*30cm*9cm=9.54 liters
You'd be able to run 2x GTX 980 ti without too much trouble.
Email sent.@Everyone:
If anyone is interested in bifurcated Risers
You can reach me:
risers@peine-braun.net
TechTach: Can't PM you, please write an email to above adress and provide further details.
Has anyone here tried doing a 4-way sli with the latest 2080ti using Bifurcation?, is it possible to do it without a sli bride/nvlink or do we need one?
