PCIe & AGP Mobo??
Revant
I'm currently in the process of upgrading my computer and i wanted to try to do it in steps, i currently have a
Intel P4 2.8 C
1Gig Dual Channel Corsair XMS DDR400 Ram
Radeon 128MB 9700 Pro
ABit IS7 Mobo
etc etc...
I wanted to buy a Athlon 64 4000+ and a mobo and just put those into my system untill i got the money for a BFG 7800 GT OC, but cant seem to find any mobos that support both PCIe and AGP i was wondering if any one knew of and boards that support this that arent terrible... or if theirs any kind of PCIe to AGP bridge you can buy? i cant seem to find anything of the sort but i though some one here might know better...
I would kiss you if you weren't a man.... Thank you so much no to just see how the board reviews, As long as the PCIe x16 support is fully inplace im fine with limited AGp use i just want to be able to use the card lol! a good price point on it as well
The ASrock doesnt run Dual Channel DDR thou, i already got a Gig of that would prefeer a board that uses it, money not really a factor i just kind of get it at a slow rate hehe...
Dual Channel RAM does not exist. Your "Dual Channel RAM" is actually the same as any other RAM, but you purchased it together. So you will be able to use it in any system that supports DDR ram at your speeds even though it says Dual Channel on i.
The ASRock board does support Dual Channel though. Look at this link:
http://images10.newegg.com/NeweggImage/productimage/13-157-081-02.JPG
look by the ram slots. Says Dual Channel 400.
And Dual Channel does not offer much for AMD processors. Nothing noticable.
If it's a s939 chip, it's dual channel.
ah sorry i was just going off the specs on New Egg hehe thanks for the info!
