PCI FAN Question
I always have used Antec SmartCool series fans and they are very effective and quiet. Here's a 120mm one on eBay.
not exactly wat i was thinking...but is that quieter than the stock 120mm in the qpack?
http://www.silenx.com/productcart/pc/viewCat_Z.asp?idCategory=3
Check out the 120mm and 80mm's for the case you have. Those are the fans I am going to get to replace the case fans in the X-Qpack2 when I get mine here in a week or so. Only thing is they are kinda pricey, but I'm sure you could find them cheaper if you do some searching around on the www. Also, if you are one that wants an LED version, they have them as well, for a little more $$$: http://www.silenx.com/productcart/pc/viewCat_Z.asp?idCategory=21
They make PSU's and HSU's as well. I am likely going to get one of their HSF's too, the 120mm version there.
