pci express
Depends on what kind of card you're using. Generally speaking, not much difference until you get to high end video cards.
using a hd4890 at the moment but may upgrade to a 5870 soon :)
may have to upgrade rest of system so i dont get a bottleneck
GPU itself doesn't matter, application load determines bandwidth requirements
no performance issues are noted between x8 PCIe and x16 PCIe 2.0 in real world testing (x16 1.x is equivocal to 2.0 in terms of bandwidth)
no reason to upgrade just for the PCIe slot, unless you like buying into hysteria
