pci-e question for quad core system
jfkriege
I am going to be upgrading my machine to a q6700 here in the next little bit. I am looking at motherboards and running into a problem deciding on chipsets to look at. I would like to have a 16x slot for my GPU, but i would like another pci-e slot that will accept an 8x Areca RAID card.
I need to know what chipset(s) would allow me to have at least a 16x and an 8x pci-e. Alternately, if anyone knows that i could run the Areca card in a 4x slot then i could do that.
I will not be overclocking the board and am just looking for a stable workhorse for editing.
Thank you for recommendations.
Joshua
X38 (and X48) as far as I know is the only intel chipset that will do that. It may be possible someone made a "special" board with the 965 or P35 chipset but "normal" per Intel configurations of those were 16x and 4 x at best.
No clue here.
bringing this one back up......
i was just taking a look over some mobos with this exact thing in mind, and the Foxconn X38A appears on the surface to be the ticket....it has 2 PCI-e 16x slots, and 1 PCI-e 4x slot (plus 2 PCI-e 1x slots).
my question is this:
how well do PCI-e RAID cards work in PCI-e slots that were designed for graphics use? or does it really matter?
i'd hate to shell out almost $700 on an Areca ARC-1230 to put in this motherboard, only to find out that it doesn't work...... :eek:
anyone here actually used a PCI-e 8x Areca card in one of these type mobos?
PCIe slots are not designed for graphic cards, they are just an interface. If you have a PCIe slot that is x16 in width, and either x16 or x8 electronically, then you will be just fine with that card. Heck you could even get an integrated video motherboard that only has 1 x16 slot and plug that card into it (not that it would be much fun).
Jason
