PCI-E 2.0 Compatibility issue with PCI-E 1.0a
hello
wants to buy an 8800gt, 9600gt or HD 4850 for my old PCI-e 16 motherboard. The only problem is that his motherboard (MSI MS -7184 with game with is HP pc) only supports PCI-e 1.0a.
This is a problem as according to Wikipedia is that “PCI-e 2.0 is backward and forward compatible with PCIe v1.x. Graphic cards and motherboards designed for v2.0 will be able to work with v1.1 and v1.0, and vice versa. In some rare cases it is possible that a PCI-E 2.0 card will not work correctly on a PCI-E 1.0a slot. This is only limited to certain video cards”.
There a way around this by flashing the bios but I don’t want to voided his warranties.
I mostly want the 4850; I don’t not want to buy an incompatible good.
So
1) is my PCI-e 1.0a motherboard compatible with the new PCI-e 2.0 cards (my chip is AMD/ati chipest sheet xpress 200 and not VIA)
2) I reads somewhere that only VIA PCI-e 1.0a. Motherboards (what is that?) have problems while Intel and AMD chips (my chip is AMD/ati chipest sheet xpress 200) work fine, is this right?
Thanks for your help
Not sure ATI/AMD specs on their sight:
ATI Radeon HD 4850 System Requirements
PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode)
Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
Minimum 1GB of system memory
Installation software requires CD-ROM drive
DVD playback requires DVD drive
Blu-ray™ playback requires Blu-ray drive
For a complete ATI CrossFireX™ system, a second ATI Radeon™ HD 4850 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per graphics card (included) are required
a PCIe 2X card will work just fine in a 1x slot as long as it gets enough power
