PCI/AGP speed info
Sparrow_69
I'm currently running an A64 3000+ @ 2.4ghz on a 240mhz bus. However, my ram is at stock 400mhz because of a 5:3 divider. Because of this, are my pci/agp buses overclocked or not? Are the pci/agp bus speeds derived from the cpu fsb or ram fsb? I've installed Sandra but can't seem to find what the agp/pci speeds are. Any help would be appreciated
What motherboard are you using and does the bios have an option to lock agp/pci bus?
Its the motherboard in my sig, the Asus K8V deluxe. No, it doesn't have an Agp/pci lock, so I"m pretty sure the agp bus is at 80mhz and pci at 40mhz...
Did you test it at all with RAM dividers and such? Run your RAM at 200mhz and see what your PCI/AGP bus runs at.
My ram is at 400mhz. Its on a 5:3 divider, but with the higher FSB, its at 400mhz. I can't seem to find where in Sandra the info about the bus is displayed
I used the program ClockGen to tell me what my bus speeds were set at. I never looked to see where it is in Sandra. If I fire it up tonight, I'll check it out.
