Hello,
I'm thinking of upgrading my PC a bit.
Here's my current setup:
CPU: E6600 @ 2.4GHz
MOB: Intel DP965LT
RAM: 2x1GB DDR2 667MHz
GPU: Leadtek 7600GT 256MB
HDD: Western Digital 250GB
PSU: Topower TOP650P5 650W (2 +12V rails, one has 20A and the other 18A)
MON: BenQ LCD 17" @ 1280x1024
CASE: Simple with 2 fans and 1 vent on the right side panel
I'll upgarade this: CPU, GPU, Case + fans.
Here's what I'm thinking of:
CPU: Q6600
GPU: 8800GTS 512MB (G92)
Case: CoolerMaster RC-690 + 3 120mm exta fans
I'm not getting a case for overclock, I just want to make sure that the 8800GTS wouldn't get hot, because I have a simple case. As well as lower the temperature of the other components because the summer here is hot.
If I bring the Q6600 do I need to upgrade my mobo? (I'm not overclocking it).
I saw in Intels website that in order for my mobo to support the Q6600, I need to update the BIOS, If I update the BIOS, is there any risk that somthing would go wrong?
Also, I might be able to exchange my E6600 with the Q6600 and pay the difference.
I wouldnt get it if I cant exchange it or if the difference is high, in other words i'm not going to pay the whole price, i'm just thinking that if i exchange the E6600, it would be worth it.
Lastly, is my PSU enough?
Any opinions?
Thx
CPU: E6600 @ 2.4GHz
MOB: Intel DP965LT
CPU: Q6600
Any opinions?
Thx
