PC unstable / slight lag / freeze
beware
Hi I built a new cpu.
Posting: it takes a few seconds before it posts and hangs. Booting into windows takes longer than expected. Once Windows boots, it seems the entire OS is locked up by the time i get into windows then it eventually loads. If I open firefox it hangs until everything loads. Sometimes when I click a window title bar to move it the pc freezes for a second. Any advise? I have flashed to latest bios.
GIGABYTE GA-970A-D3
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz
Trying to follow this thread http://www.gskill.us/forum/showthread.php?t=7688
is getting me nowhere.
My mobo manual is here:
http://download.gigabyte.us/FileList/Manual/mb_manual_ga-970a-d3_e.pdf
HIt up the stickied "Basic Troubleshooting Guide" and start from there.
Also full specs of the PC would help.
Sounds like a possible RAM error or driver issues.
BTW, was it hard to build a cpu? :D AMD or Intel might want to hire you. ;)
