PC problem Need help
osmosis
My rig :
P4 3ghz
IC7
Antec 480W Psu
2X256 hyperX PC3500
Geforce 4 4200ti
1 Hard drive
2 CD-roms
Audigy 2
My main problem is my PC keeps giving me BSOD, The main Errors i get are
0x0000007f and sometimes Bad_Exhandle 0x000000A7.
I have ran Memtest86 and i was getting Errors on Test #4 , the bad address is 7fffffff. I
decided to underclock my Cpu to 198FSB (2.97ghz from 3.06ghz) and tried the test and then the Errors disappeared.
Also if i run the ram at 2.6V i get tons of errors, so i have to drop it to 2.5v.
I have the latiest Bios and chipset and i do not overclock.
Since I underclocked i have been getting some BSOD but the errors have been different, i should have enough cooling and my temps are
system 25C
processor 47-50C - idle / 61C under load
power 37C
Could anyone here give me a clue as to what is causing this problem? CPU Mobo ram :confused:
Some Friends think it is the motherboard but i would like some opinions before i RMA something.
any help is really appericated
clear ur bios to factory default. use only one of your ram sticks and try. then both
Thanks for the help, Running on default settings. So far so good, i will post again if the errors come back .
Default settings did not work
I have searched for the error codes 0x7f is CPU releated. i could not find that much info on the other one.
If it were the CPU , why would the errors change after the Ram errors go away?
