Thanks in advance to Danny Bui and others, you guys are the best!!
Gaming will be the primary purpose, (A lot of WoW for now, but certainly Diablo III later and I will dabble in other games) there will be Photoshopping and Video Production/Editing as well.
I'm not super strict on a budget; if I can swing under $1000 all told that would be great. I have Amazon Prime.
3) Where do you live?
Connecticut; I have a Microcenter within driving distance, but no Fry's.
CPU
Mobo
RAM
Video Card
OS/Apps Drive (SSD)
Optical Drive (Black Bezel and Blu-Ray would be nice)
PSU: PC Power & Cooling 750W Silencer Quad
Case: Antec P180
Sound: ASUS Xonar DX
Storage Drive: WD Caviar Blue 640GB 7200rpm SATA 3gb/s
6) Will you be overclocking?
Wasn't planning on it; but if it's very easy and reliable I would consider it.
37" LCD Panel @ 1920 x 1080
Next couple weeks; shortly after my tax return arrives.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I would consider Crossfire/SLI, but the last few mobos I've gotten have had the second pci-e x16 slot and I've never used it.
eSATA and USB 3 would also be nice features to have.
I have a Windows 7 64-bit license.
Here's what I'm looking at right now; but I haven't built in a long time, so I probably got some things off: (I'm a little shaky about my video card choice.. I've read mixed reviews on the new Ti cards but it looked pretty decent on anandtech's benches)
$180 (@ Microcenter) CPU: Intel i5 2500K (Figured I might as well go for the unlocked one as it's only a couple bucks more)
$140 Mobo: MSI P67A-G45 (B3)
$95 RAM: G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) DDR3 1600
$218 (after rebate) Video Card: EVGA GeForce GTX 560 Ti FPB (Fermi) 1GB
$180 (after rebate) SSD: OCZ Vertex 2 OCZSSD2-2VTXE120G 2.5" 120GB (I thought about getting a SATA 3 drive, but I figured what I may do is go with this for a bit, then when SATA 3 drive prices come down, put this drive into my laptop, and get a new SSD for my desktop. This was the reasoning behind going with the 2.5" version.)
$80 Optical Drive: LG WH10LS30 10X Blu-ray Burner - LightScribe
$893 Total
I would appreciate any comments and input you guys may have!
CPU
Mobo
RAM
Video Card
OS/Apps Drive (SSD)
Case: Antec P180
$893 Total
