I want to build a new gaming PC. I am planning to spend $800 or less (less is better!).
I want to go with the AMD A8 CPU because it's cheaper than an i5. The i5 I would like is the i5-3470 and the A8 I want is the 5600K.
I'll be putting the Geforce 650 Ti 2gb and 8gb 1600 DDR3 RAM in the PC also, regardless of CPU I'm going with. I render video with Sony Movie Studio and that uses CUDA cores to speed up rendering so I'd like to stick with Nvidia. I think it will use ATI to render as well, but I'm not certain of that and the 650 Ti looks to be what I'd be happy with.
My current PC has these specs (Asus Laptop) so you guys can see what I'm moving from:
Intel Core i7 2670QM @ 2.20GHz
8.00 GB Dual-Channel DDR3 @ 665MHz
2047MB GeForce GTX 560M
Decent laptop, runs most games on Medium around 40-60fps. I'm wanting to move up to 60fps on High-Ultra settings though.
Opinions on the A8 vs the i5? Should I go with the i5 even though it bumps the price up almost $100 more? I know it's better, but is it THAT much better? I've read Skyrim is CPU limited, but I don't know what that means really when the GPU matters most in video games (or always has for me in the past).
System build questions/answers below, if needed.
1) What will you be doing with this PC?
Gaming
$800 total.
3) Which country do you live in?
US, North Carolina.
4) What exact parts do you need for that budget?
CPU, Motherboard, RAM, Video Card, Power Supply, Case, Hard Drive, CD-ROM.
5) If reusing any parts, what parts will you be reusing?
None.
6) Will you be overclocking?
Just the graphics card with MSI Afterburner.
1920x1080. 22 inch. May run 2 of these, but of course will just game on 1.
No set time. Near future hopefully (before Christmas).
9) What features do you need in a motherboard?
Something that will last.
I already have Windows 8 Pro 64bit or Windows 7 Pro 64bit. I plan to use 8.
Gaming
$800 total.
US, North Carolina.
None.
