PC for a friend
Rydawg5143
Used for general gaming ( tf2, hl, cs:s. etc) web stuff and random other stuff
700ish budget, 19-22 monitor, Will be OCing,
e7200 from MC for 100
ep45-ds3l-108
Sonata 3 w/ 500w PSU- 120 ( buy.com)
4 gb G.skill for 75
WD3200AAKS- 65
Xigamatek 92mm- 27
4850- 160ish
Unless listed it is from the egg. I'm pretty set on everything cept the case/psu as i think i can find something for a lil cheaper.
You may want to search around a bit for the HD4850. Some of the models found at NewEgg are starting to run out of stock.
Those prices, for the most part, are pretty accurate. I take it you already have a copy of Windows handy?
Parts choices looks good to me. I'm actually a bit surprised that you're going back to Gigabyte after your experiences with it. Then again, those problems were related to the external drive you had...:D
Though if you do find a cheaper case/PSU combo, run it by us first. Some of those Case/PSU combos have shitty PSUs...
im trying to stay with corsair or antec EA as those are the only 2 types I have had not die on me :) but seems no good deals on case/psu atm
antec's neo line of PSUs is also made by Seasonic. Their Truepower Trio/Quatro line is ok, too, but not as good.
Why pay extra for the P45 version of the DS3L?
Get the P43 instead for $20 cheaper. Who knows, they may just send you the P45 version (happened to me).
I bought a dozen when i built my PC couple months ago :)
SOmone should sticky that build so when someone comes in here and says ' i need a cheap gaming computer' They can get ideas :p
A dozen xigmatek brackets? Can I get one? :)
Prices change over time, and new parts become available, so a sticky isn't the best. Kinda like that recommended parts page... the OP of that thing rarely updates it, or if he does, he doesn't bump it, so its not a sticky.
You could also get A-Data ram for $5 less. Plus you get a 2GB Flash drive for free.
NewEgg still has the G.Skill 4GB DDR2 800 kit available for around $80 shipped.
