Hi all, please bear the incoming wall of text - I'll try and make the points as concise as I can. Please help this scared college student :[
Memory checked out by Windows, OS drive is probably fine but the volume/Windows data may be corrupted, graphics card is fine as it's outputting normally...
My guess is either 1) corrupted Windows (doubt it now due to the SMOKE) 2) broken PSU or 3) broken motherboard.
I did not see any broken or charred capacitors from my visual scan of my mobo, but I could have missed them/they could not be obvious.
My system: (Windows 7 Pro x64)
OS Drive is Intel G1 80GB SSD
CPU: Intel Core2 Q9550
RAM: 4x2GB Gskill 1066 DDR2
Mobo: Gigabyte EP45-UD3P
PSU: Corsair TX850W
Sound: Creative X Fi
VC: Nvidia GTX 285
Please help! After I get some sleep, I'll be trying first
1) swap PSUs (I have a spare 750W)
2) reinstall Windows
3) RMA mobo (probably no matter what though now, as I don't trust it)
I can take any pictures/request if needed in order to help me solve this! Thank you!
- This morning I decided to boot up my computer - the computer gets stuck on the Windows 7 boot screen (with the Windows logo).
- So I decide to retry booting... still no luck, and I remember last night as I shut down, it got stuck on the shutdown process (which I thought was weird, but not uncommon to Windows) so I held down the power button to force power off.
- I then try the Windows Repair Mode... it gets stuck on the stock blue Win 7 blackground, no cursor or anything... so again, I shut down.
- The next time I try to boot up, the system emits a bit of smoke from the rear and has a sweet smell, to which I quickly shut it off.
- I unplug everything, power cycle, then only plug in my kb+mouse, and boot to BIOS. BIOS is OK - I can load profiles fine, it detects my hard drives, etc.
- I try Safe Mode - it takes forever on the driver/sys file classpnp.sys, but eventually loads... to my dismay, it takes forever again to get to desktop, and when I check [My] Computer, no drives (or ANYTHING!) shows up... Bad sign!!!
- I then try the Repair Mode again... which works, albeit really slow loading it, which probably took just as long the first time, so I wasn't waiting long enough, not a good sign.
- It finds no problems - WTF - and I can post the summary of all the diag tests it did (System disk check, Disk failure check, Disk metadata check, .etc) but they all passed.
- I then tried the memory check after the Repair did not find any problems - the memory test passed %100, then Windows decided it should try and boot again...
- Windows boots, however, just like before, it takes forever at the logo, and it comes to my login screen. I log in, but rather than being a few second/instantaneous login, it takes longer than normal, then just ends up on a black background with the cursor, and stays that way for 5 minutes before I shut down again.
PSU: Corsair TX850W
VC: Nvidia GTX 285
