The issue is this:
When I make contact with the PC: by hand, by setting side panel against case, or (especially) by usb or esata (even before it's connected!),
it: Crashes.
It used to give a black screen with red streaks, and then restart. Some times it restarts instantly. Some times it locks up. Some times it locks up as if the HDD was disconnected (the mouse still moves), and then restarts after a delay. Some times it locks up and restarts 5s later.
What else can I try? I am rather amazed at this point.
Thanks.
These are the solutions I have tried:
Part/Issue listed first.
The variations of that part I have tried listed between ----'s
Case:
HAF 932 ---- NZXT Beta Evo (Known Good.)
GPU: Never crashes during games.
6950 2gB ---- 9800 (Known Good.)
RAM: Passes memtest.
Mushkin Silver+Ripjaws ---- Mushkin Black (Known Good.)
HDD:
Samsung RAID 0 ---- SSD Agility 2 (Used separately(disconnected), still crash.)
PSU:
Antec HCG 750 ---- Seasonic Gold 750
Power Source:
6-plug strip ---- CyberPower 810w UPS (Appears Good, other PCs do not crash.)
Optical Drive
DVD-RW (Known Good) ---- DVD-RW ---- Blu-ray
Mother Board:
AsRock 880G Extreme 3 ---- Asus P8P67 Evo, Rev. 3.
CPU:
1055T (Known Good) ---- 2500k
Case Fans:
Set A (ALL Replaced or Removed) ---- Set B
Extension Cable or Adapter:
CPU 8-Pin (REMOVED) ---- 3 to 4 Fan Adapter (Was not used until months after the crashing started.)
SATA Cables:
Sound Card:
X-Fi XtremeGamer Fatal1ty (Known Good) ---- X-Fi Titanium ---- Neither
Video Cables:
(All Tried Separately)
Front Panel I/O:
Connected ---- Disconnected (Completely disconnected any such thing except (obviously) the rear mobo connections.)
125v Power Cable:
A ---- B (Known Good)
PC Placement:
On Carpet ---- On 10" x 22" Board
Heatsink:
S1283 --- NH-D14
Overclock:
With (1055T) ---- Without (2500k)
Note on Outlet/Power Source
Second, third, fourth, and fifth PC Never crash like this.
it: Crashes.
Thanks.
Case:
HDD:
PSU:
Power Source:
Optical Drive
Mother Board:
CPU:
Case Fans:
SATA Cables:
Sound Card:
Video Cables:
Front Panel I/O:
125v Power Cable:
PC Placement:
Heatsink:
S1283 --- NH-D14
Overclock:
