PC Chips m811 & Radeon X1600 compatability problem
Kusaywa
I have a PC Chips M811 MB and when my NVidia Geforce 2 Pro AGP is installed it starts up fine. When I recently installed a Radeon X1600, it wouldn't start. If I held in the start button to turn off PC, and then tried to start, it would start and run fine after that. The X1600 is a 8X AGP and the NVidia is a 4X (I believe). The MB is only supposed to use a 4X but the X1600, once started, runs fine. There is no bios update for this board, and I would love to use the X1600, but it's my kids computer and the startup problem is frustrating (he's 6). There is nothing in the bios to change to 8X, only 2 & 4. Is there a way around this problem?
hmm weird.. sounds like a conflict between the card wanting 8x and the board wanting 4x.. i know how it goes with kids and frustration.. my little cousins the same way.. by and chance when you start the system up and then hit the reset button during post does the system start up fine? may be an easier solution for the kid if it does.. but as far as why its not working correctly.. your guess is as good as mine..
also i cant remember but does the x1600 use an external power source or is it all run off motherboard power? since i know my x1650pro has the 4 pin connector on it.. im wondering if maybe the problem isnt the board but the power supply depending on which one you have and what the rating is on it..
It does have the 4 pin connector, but I'm not sure what the power requirement is for the card. I have a 400 watt PSU, which should be ok. But like I said, it doesn't boot, not even bios info the first time. If I power off with the power switch, it will start on the second try (usually). STRANGE!
400W is plenty. I would guess that it's a board issue perhaps with the power through the AGP slot?
8x is backwards compatible with 4x only.
4x backwards to 2x only.
Something like that.
It should work, but the card is negotiating down to spec.
I'd blame the PC Chips mobo.
