That is a great idea. I'd love to see something like this.
Just go to Newegg, add what components you wish and check the total balance in your cart.
Voila.
Seconded. If you don't know enough to know what to pick then you should do a little more research before building a PC.
1) Start with the processor you want.
2) Decide what kind of graphics solution you want.
3) Pick a motherboard that is compatible with cpu, supports the number of GPUs you want and has any features you may want.
4) Get system memory that is listed on your motherboard compatibility list.
5) Get a case that will fit your motherboard and any peripherals and storage you want (If you're getting a high performance graphics card ensure that your case is long enough).
6) Pick a high quality power supply sufficient to power your build and ensure that you have a decent cpu cooler and enough fans to ensure air flow through your case.
7) Don't forget misc extras such as thermal paste for the cpu, brackets if you need them for SSDs, connectors and cable ties.
Voila.
Hi all,
Is there any good Up to date, site to custom build your pc (simulate) and see how it cost .
