hello there hardforum! found the place via a google search, and lol´d hard of the Q/A thread with the alienware case questions lol... so thought i would share my latest project with you
still trying to figure out the forum. so please tell me if i made a boo boo somewhere in the post
other than that, i can only say enjoy! this is the first of 2 updates. progress is slow since im in school atm, but there should be some serious lazor action within a month
and now for:
thx to Itrends.dk for helping me out on this one.
lets jump right into it. as usual i am modding an old used case!
the inspiration?
the case, and plans.
im going to watercool the system with a 3*140 mm radiator in front, and two pumps. as seen on the pics, the case is devided in 2 sections. the frame is going to be powdercoated in matte black.
this is some of the evelopment of the cad drawings i made. the big round one on the left is going to be a window.
and the finished drawings. the top drawings is going to be cut in folie, and the bottom one in green acrylic. since ac-ryan didnt reply on my mails, I found the same acrylic that they uses (for 1/4 the price) and will be using that.
finished middle plate
the middle plate is going to be bend around the frame, to give a smoother look
the little room in the top will be sealed off, and most likely used for 2 harddrives.
close up of the rad hole in the front
on this pic, the folie looks quite thick, but it wont be
the motherboard tray (yes, that old bucket have a removeable mobo tray!) is going to be made of 2 pieces of acrylic. black and green, and will look like this
for pumps holders, i designed a bracket, that will fit on 140 mm fans to hold the ddc pumps. with rubber grommets, theese should reduce vibrations too, and the cold air from the fans will cool them down a bit.
close up of the bracket.
hardware is yet to be decided. but for watercooling i will go for theese 2 for certain
2 ddc pumps
HWLabs black ice gtx 420 radiator
soo.. hoped you enjoyd this little start of my new project though it almost only consists of renders. more WILL come. (already got a lil´ testplate cut out to play with
-p0Pe
and now for:
the inspiration?
2 ddc pumps
-p0Pe
