Patriot memory and DS3
brownbomber
I talked gigabyte tech and they told me the reason my motherboard will not boot up in dual channel is because my ram is not compatiable with my motherboard. this ram worked perfect before I rma my video card. anyone using patriot memory with their ds3 motherboard.:confused:
Are you sure the Dimms are in the right slots for dual channel operation? If your memory wasn't compatible with your board, it wouldn't boot or would be unstable.
Yes i am putting them in the 1 and 3 slot or the 2 and 4 slot . no go but when I put them in the 1 and 2 slot it will boot . this ram work with my asrock board . So I believe I need to RMA this board.
thats weird because i've never had problems with my ds3 and patriot ram whatsoever, running in dual channel included.
Are you sure your memory timings are set correctly? Are slots 3 and 4 bad? Have you tested each individual slot by itself? Have you tested both sticks of memory?
That sounds similar to a problem I had with a recent DFI board. Put it in slots 4, then add to 3, and it'd boot. Put it in slots 1, or 2, or 1/3, 2/4, and it'd just look at you like a tired dog barking "C1". Turned out it was bad slots, and I'm still using the RAM with no problems, on several newer boards. So I'd throw in that it's your board... whatever the reason.
