Password Cracking Rig: Build Critique Requested
Status
Not open for further replies.
int0x80
A friend and I inherited five R9 290x to build a password cracking rig. Along with the cards, we have an open air frame and two EVGA SuperNOVA 1000 G2 power supplies. We created our builds independently but they're almost identical. I went with a different SSD that is $20 more expensive and half the capacity but has better performance.
Would you please critique our build? We are flexible on budget but would need to see significant performance gains to justify an increase in cost.
Requirements:
Mobo: 5x PCIe 3.0 (R9 290x), 1x PCIe 2.0 (SSD)
His build:
CPU: Intel i7-4770 3.4GHz - $290
Mobo: ASUS MAXIMUS VI EXTREME - $353
RAM: Crucial Ballistix Tactical 32GB - $320
SSD: Crucial M550 512GB - $368
My build:
SSD: Samsung XP941 256GB - $390
If the only use is cracking, SSD speed is likely irrelevant. So I would opt for the larger one.
You can gain useful info from this guy's experience.
Thanks, I saw Jeremi's interview on Hak5 a while back but had forgotten about it. I don't recall any info about his storage or CPU in his interview and there doesn't appear to be any info about them in his slides.
The difference was 500 MB/s read and write vs. 1000 MB/s read and 800 MB/s write. I should just look for bottlenecks to see where the slowest points for data flow would be.
Considering the gpu power applied, I could see it as an issue if doing a dictionary attack, but something like that seems more on the brute force lines which would be raw compute. I've only done wpa cracking for kicks back in high school so my experience is very limited, so I'm just throwing ideas out there as the topic intrigued me. :)
You can try reaching out to him on twitter with questions:
https://twitter.com/jmgosney
Storage I/O is only important if you use rainbow tables.
Rather be safe than sorry so thread locked.
Though seriously, for that amount of money, the X79 platform is better.
Status
