So I'm setting up a new system in a Corsair 380T ITX case:
Graphite Series 380T Portable Mini ITX Case
CPU is an i7-6700 (non K).
Motherboard is an ASRock Fatal1ty Z170 Gaming-ITX/ac:
ASRock > Fatal1ty Z170 Gaming-ITX/ac
The Corsair 380T has a max heatsink height of around 150mm. Tried the Cryorig H7, but its massive backplate got in the way of the M.2 drive. I'd rather not use liquid cooling since I'd be adding pump noise to the system.
So now my next choice for heatsink is the Noctua NH-U9B (any of its variants would fit in the case).
I have a 200mm fan on the front of the 380T and a 120mm fan on the exhaust / rear of the case.
The NH-U9B would be sitting directly between the two fans. Since the i7-6700 is only 65W, would this setup be sufficient in cooling the CPU or should I still add a 92mm fan or two (push/pull) to the NH-U9B?
