Parts List: Need some advice
refraxion
Hi everyone,
I'm in the market to upgrading again and was wondering what you guys thought on this bundle of the Core i7 2600K and Asus Mobo:
http://www.memoryexpress.com/Products/PID-BDL_Z68VPRO_2600K(ME).aspx
How is the motherboard? also, is that a good price? I've been out of the loop on pricing for a long time.. (Since Q6600)..
What would be a good pair of ram for a machine like that (If I'm to use it for CADD work?). I'm mainly looking at buying off Memory Express (Since they have UBER PRICE BEAT) for all Canadian retailers.
I'm also looking for a good SSD to use as an OS drive (And maybe install SC2/Diablo 3 -- so looking for a 128gb SSD drive). What is good and at a decent price? Does read/write speed really matter for what I want? Or does any SSD work? I'm focused mainly on loading times for the two games and OS.
I'm also thinking of buying a beefier Power Supply.. just in case I crossfire/SLI down the road. Is a 1200 watt PSU the bare minimum these days for Xfire/SLI?
Is air cooling still effective in comparison to the new all in one liquid cooling systems? (H50 etc.)
I'm going to be keeping my video card until the next ones come out by ATI/Nvidia..
AMD Bulldozer is taking forever to come out.. and if it doesnt come out by this month or beginning of next month.. I'll be going Intel once again...
The Asus board is fine and its price is comparable to what you could find in the US.
With the Intel Sandy Bridge processors, all that you need is DDR3 1333 RAM. Out of what's available at Memory Express, I recommend buying two Corsair XMS3 4GB sticks. Yes, they cost a bit more than the 8GB dual-channel kits that are on sale....
As for the CPU cooler, I recommend the Cooler Master Hyper 212 Plus. It's what we often recommend for those looking for a good yet cheap third-party CPU cooler for overclocking. However, the tower design can interfere with RAM sticks with large heatspreaders -- the XMS3 heatspreaders don't extend much beyond the normal height of the RAM.
We recommend two brands for SSDs: Intel's 510 series and Crucial's m4 series. Those two perform well and are very reliable. Currently, all SSDs using the SandForce controller are having various issues; the two aforementioned SSDs use a different controller. However, the online Memory Express store seems to have few options. I chose the Intel 510 120GB SSD because it's available, but you should try to look for the Crucial m4 128GB SSD (it's oftentimes cheaper than the Intel SSD).
For CrossFire and SLI, we recommend at least 850 watts (for high-end cards) and at least 60A combined in the 12V rail(s). Corsair, Seasonic, Antec (its new HCG series), and Silverstone are a few of the vendors that sell good power supplies.
For better advice, please answer the sticky questions. With more information in our hands, some of us here could offer cheaper yet still effective alternatives.
Thanks for the response!
I'm mainly building this for gaming/ work (cadd work)
My budget is $1500-2000.
I have my eye on the m4 and I'll be using a terabyte caviar black drive too (adding to the parts list).
I am also planning on overclocking, how good is the 212+ for that? Seems like coolers have gotten cheap!
Also, I've been looking at a new case as my cm690 is no longer cutting it, what case would you recommend that's cost effective and can handle SLI/XFire?
The CM 690 isn't cutting it? I find that hard to believe as the CM690 II cases are based off the original CM690. If you want a cost-effective alternative, consider the Cooler Master HAF 912; it's larger than most ATX mid-tower cases in its price range.
Consider the Samsung HD103SJ 1TB hard drive in lieu of the WD Caviar Black. The Samsung performs just as well but it oftentimes costs less.
As for overclocking, let me put it this way: You could easily go beyond 4GHz with either the i5-2500K or the i7-2600K. And yes, that's with the Hyper 212 Plus and DDR3 1333 RAM. (Because the K series Sandy Bridge processors have unlocked CPU multipliers, which are the collective key to overclocking these processors, you don't need to touch the RAM.)
Interesting... so the Hyper 212+ keeps it cool at around 4.5ghz OC (Provided I get that high)? That's pretty damn awesome for the price.
I have the CM 690 case.. is the CM 690II case a bigger improvement?
Btw, my budget of 1500-2000 is going to include future video cards that come out. But I am holding off on that for the moment until AMD releases their next cards most likely.. my 5870 will have to do for now.
The rest of my current specs are in my sig.
IMO, neither of the CM 690 II modes (Basic or Advanced) provide enough of an improvement to replace your current CM 690 case. The Advanced case does come with more fans, a 2.5" adapter (for SSDs), and an external SATA dock, but the internal volume is pretty similar to the original CM 690.
You have a TRUE already? Did it come with an LGA1156 mounting kit? (If so, it will work with your board. If not, Thermalright makes several mounting brackets based on the particular model of your heatsink.) You TRUE would perform about as well as the Hyper 212 Plus.
I don't know if my TRUE came with one or not, I'll have to check.. was LGA 1156 even out when the q6600 first come out? Lol :p.
Also.. what would be recommended for CADD work? I'm guessing the i7 2600k over the 2500k?
I really need a tower that will be large enough to handle SLI/XFire of current generation cards.. any suggestions? Which one has really good cable management / airflow? Also, in the long run.. wouldn't the 2600k be better than the 2500k at 2560x1440 resolution?
Just buy the LGA 1155 or LGA 1156 bracket then. The TRUE is a really good HSF.
Yes.
I recommend these cases:
$120 - Corsair Carbide Series 400R ATX Case
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Lian Li PC-9F ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$143 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$150 - Corsair Graphite Series 600T ATX Case
$160 - Silverstone RV02B-W ATX case
$178 - Silverstone RV02B-EW ATX case
$190 - Corsair Obsidian Series 650D ATX Case
$220 - Cooler Master ATCS 840 RC-840-KKN1-GP Full Tower ATX Case
$230 - Silverstone FT02B ATX Case
$220 - Lian Li PC-A71F Black ATX Case
$230 - Lian Li PC-V1020A Silver ATX Case
$250 - Lian Li PC-V1200B Plus II Black ATX Case
$270 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
$330 - Silverstone Temjin SST-TJ07B Full Tower ATX Case
For gaming? No. For CADD work, yes.
intel is the best for ssd. i know this is kind of expensive but it worth and have the least problem in all of the brand.
Crucial M4 SSDs are stable performers while costing a good bit less than the Intel 510 series.
Thanks guys..
So here is what I'm thinking of getting so far:
Intel i7 2600k bundle with the ASUS Mobo.
The 2x 4GB Corsair XMS sticks (Or do I need 3 if I'm into CADD? How does DDR3 ram work on the new motherboards now?)
I'm still thinking if I should go Intel 510 or Crucial M4 (128GB)..
1TB WD Caviar Black HDD
CM Hyper 212+ Cooler (Is TRUE or this better?)
For Cases.. Is an Antec 1200 Gamer case large enough for SLI/Xfire of the current gen cards?
Thanks guys..
Good choice.
Triple channel memory has no benefit on the LGA 1155 platform. Just get 2 x 4 Gb sticks of DDR3 1333 @ 1.5v. If budget allows, I'd max out the RAM at 16Gb since RAM is really cheap right now.
Both SSDs are good choices, Crucial being the cheaper.
It was recommended in previous posts, but I will recommend it again. Get the Samsung HD103SJ 1TB instead of the WD hard drive as the Samsung performs as fast, if not faster than the WD drive for less.
Go with the cheaper CM 212+. It works wonders at only $30.
I recommend these cases for SLi/Crossfire.
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$100 - Lian Li PC-7FN ATX Case
$110 - Lian Li PC-60FN ATX Case
$113 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$110 - Fractal Design Arc Mini Tower
$130 - Fractal Design Define R3 Black ATX Case
$140 - Antec Performance One Series P183 V3 ATX Case
The TRUE is better. The LGA 1155/LGA 1156 bracket is also relatively cheap. So get the bracket for it since you already have the TRUE.
Yes and no: While SLI/XFire would fit in that case, it'd be very cramped and have little to no cable management. So go with the cases that Skillz recommended.
Thanks, I'm looking into the corsair/coolermaster cases. Also, which 850+ watt power supply on the memory express website would you recommend me in getting?
Guess I should have read the other posts, I didn't know you already had a TRUE. In that case, go with Danny's suggestion.
On that web site; I would recommend this PSU.
$144.99 - Corsair Enthusiast Series TX850 V2 850W PSU
You will need the Thermalright Venomous X 1155/1156 BTK bracket, the True ones are no longer available (at least in USA). You can also get the new pastic fan holders if you like. Performance of the True depends on the fans in use.
Thanks for all the help guys! I ended up getting the 2600k bundle, and corsair 650D case. I also chose the corsair HX 850 watt psu.. How would you rate that in comparison to the tx? Need to build it later tonight.
The HX is better than the TX
