Partial Build, remaining Parts Questions
nima620
Gaming (Starcraft and Diablo 3 + exploring some FPS)
1200-1500 for remaining parts
California
CPU, Motherboard, Video Card (or 2?) HD, Memory
Already Purchased:
XFX Black 750W PSU
Obsidian 800d Case
Corsair Hydro H70
6) Will you be overclocking?
I would like to learn/experiment w/ overclocking...
I would like to find 3 or so good quality IPS 27" monitors I can compare and choose from... any recommendations here would be great
I would like to purchase/build in the first 2 weeks of September
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I would like the ability to upgrade to 2 video cards on SLI. I would also like to experiment w/ overclocking.
I would need to purchase Windows 7.... Premium right?
I would like a build mostly for Games and some movies/media watching. Here is what i was thinking of getting
Sandy Bridge 2500K - 229
Asrock Extreme 6 p67 B3 - suggestions?
GTX 570 OC'd - good/bad? enough for light FPS shooters and Diablo3/Starcraft? http://www.newegg.com/Product/Product.aspx?Item=N82E16814127564&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
I want to go w/ boot drive SSD
HD#1: Crucial RealSSD c300 128GB Sata3?
HD#2: Samsung Spinpoint F3 1TB??
Memory: Gskill Sniper 2x4gb: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416
as far as monitor i have no clue and the pricing above of 1200-1500 for rest of parts did not include monitor purchase.
Thanks in advance for your help.
Are you looking at a 27 IPS like the U2711 with a 2560x1440 resolution or one with 1920x1080? I cannot recommend a video card till knowing that.
For starters:
Intel Core i5 2500K - $219.99
MSI P67-GD65 - $169.99 - SLI support
Corsair XM3 DDR3 2x4GB - $48.99
Samsung F3 1TB - $59.99
Crucial M4 128GB SSD - $208.70
Windows 7 Home Premium SP1 64bit - $91.98
Total = $799.60 + FS at Amazon and you do not have to tax there like at Newegg
Anyway I suggest coming back mid September actually when you want to do the build. If rumors are correct AMD's FX line up will be out by September 19th, so that may prove to be a nice CPU or at least make Intel drop prices.
Banzai - thanks for the input
I don't think i'll be spending 800$ on a monitor just yet so i would have to say a max 1920x1080 would be okay.
also, would i have any problems fitting the H70 onto the GD65?
Thanks,
Nima
If that is the case then a 570 would perform really good at that resolution, but SLI would be total overkill in my opinion. I have never heard of any issues to be honest with the H70 being mounted on boards, so I would assume there would be no issues.
I see. What are some good IPS monitors that would work here? Would you recommend waiting until Black Friday for the monitor purchases for better deals?
I can name a few 23 inch IPS monitors that are good, but I do not know any besides that U2711 to be honest. I recommend hitting up the monitors forum here at [H] to find a proper one for you.
Why are you dead set on an IPS monitor when this is a gaming rig?
Depends on what you want. I see lots and lots of gamers loving IPS monitors due to colors being that much better and adding to the gaming experience. IPS monitors are a lot better at response time now verse what it used too. With that TN even though it has a faster response time is not as critical.
Thanks for your input guys.. I've decided to pull the trigger on the rest of my parts. All amazon as suggested! (except the Video Card)
Newegg:
GTX 570 OC'd http://www.newegg.com/Product/Product.aspx?Item=N82E16814127564&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
Already purchased:
XFX Black 750w
Obsidian 800d
Corsair Hydro H70
Razer BlackWidow Ultimate
Logitech G9x
Any last minute advice?
Thanks again!
Get a higher overclocked version of that video card for cheaper at Amazon for $325.
If you did not purchase that black widow yet then stay far away from it. The quality is not good on that all I see people is complaining about it. Go with one of the Logitech gaming keyboards instead.
if you havent ordered yet, get the spinpoint f4, as its supposed to be one of the THE best spindle drives
xBanzai.
I was able to switch Video cards to your recommendation... thank you bro.
i also changed my keyboard to the logitech g510.
haunter,
I was not able to change the 2nd HD because it was already charged and in the shipping process. Thanks for the heads up though.
I am very excited for Wednesday to come :)
would it be alright if i post build related questions here as well?
Thanks,
Nima
Danny
i would like to put 3-120mm fans on top of the 800d to pull air up through the case
i would like to put a 140mm fan at the bottom (same bay as power supply) - pull from bottom
i would like to put a 120mm fan at the bottom (above the bay of the power supply)
What i'm confused about is which way the H70 push/pull should be flowing.
logically, it seems the best choice would be pull cold air in through the radiator (come in from behind the computer) and it would be pulled up through the top of the pc...
does that make sense or is there a more optimal way to keep temperatures cool?
You might want to ask that question over in the Overclocking and Cooling subforum or even the Cases subforum for more expert advice. But from what I know, your logic has two flaws in it:
1) The exhaust air from the video card and PSU. I think your card exhausts the air from the case and out the video card's rear and the PSU definitely exhausts air to the rear. As such, there's a chance that warm or hot air could be pulled through the radiator.
2) Corsair's recommended setup would dump warm/hot air into the case itself. So while the CPU may be cooler, the rest of the system won't be.
You might want to read this page and see if it helps:
http://www.hardocp.com/article/2010/08/05/corsair_h70_cpu_cooler_first_install
