Blue Hatter
- Jul 17, 2015
Hello. This might be a bit of an odd question, and hopefully this is the right place to post this, but I've been trying to identify a particular electronic part (I believe it's a computer plug of some sort, though it might go to something else) and I haven't had any luck doing so. I'm working on a movie replica Star Wars costume and the last part I need is this particular plug, but I have no idea what it is and I haven't been able to find anything remotely similar. I was hoping that someone here might know what it is, or have a clue as to something that looks similar.
The only decent picture of the part isn't all that clear, unfortunately, but here it is...
To me it looks to be some sort of double-row plastic connector on a silver metal base. There are three screw holes on one side of the metal base and it looks like there's only one on the other side, though there might also be three on that side and the other two aren't noticeable because of a shine, it's hard to say. To me is almost looks like something similar to two of these on a metal base (but probably not those exactly), but I can't say that for certain.
The part was used in Return of the Jedi, so I would imagine the part would be from around the late '70s to early '80s (Return of the Jedi was released in 1983).
Does anyone have a clue as to what this part might be or has seen anything that looks similar? I've been looking for this for quite literally years. Any help would be much appreciated. Thank you!
If it helps, I'm doing a B-wing pilot costume from Return of the Jedi. I'm doing one with some of the pre-production details. There's a picture of the plug on the costume here-- it's right under the white hose that's next to the black circle.
