Palworld
Another vote for, "I don't hate it". I'm kind of burnt out on survival games but it has its charms.
https://store.steampowered.com/news/app/1623730/view/4178847793405854409
2024/02/27 Update Patch v0.1.5.0
Steam version v0.1.5.0 has been released.
Patch Notes:
▼Major Fixes
・Implemented backup of save data on the world selection screen
・Resolved issue of unnecessary data accumulating in save data
▼Key Configuration
・Added fully supported keyboard key configuration
▼Guild
・Modified specification to allow guild members to be removed when not logged in
▼Player Issues
・Changed long-press operation during player tasks to allow continuous work by pressing the work button once (This is switchable in the options settings)
・Fixed issue where riding in prohibited hunting areas would not result in a crime
・Improved interaction accuracy with adjacent objects
▼Pals
・Changed specifications so that when a Pal is instructed to "attack aggressively," the Pal will attack enemies indiscriminately even if they are not in combat
・Corrected an issue to allow Pals of rank 1 or higher to be selected as concentrated material (higher-ranked Pals yield more points when concentrated)
・Fixed bug where if a large amount of experience points were gained and the level increased to 50 at once, Pals would not learn any active skills
・Mitigated an issue where using Mossanda's partner skill "Grenadier Panda" on a dungeon boss would cause the boss to get stuck in walls
▼Base Issues
・Fixed an issue where base Pals would get stuck on top of a logging site, etc.
・Added measures to prevent the issue where base Pals would wander around and get stuck at the border of the base area
・Fixed an issue where Pals at the base would get stuck repeatedly starting transportation tasks and the light bulbs icon would appear over and over again.
・Added measures to prevent the issue of base Pals getting stuck in the farm on a roof
・Fixed an issue where work Pals would get stuck in the summon space of Palbox when restarting the server on a dedicated server.
・Adjusted the default work priority of base Pals (Anubis will prioritize manual labour)
・Significantly relaxed building restrictions for stairs and triangular roofs
・Fixed an issue where sound would play in an infinite loop when Pals at the base used certain active skills.
・Specifications changed so that all changes in environmental temperature are added up (if you put 4 campfires next to each other, the surrounding area will have the temperature of a volcano)
・Implemented "relax" working style on the monitoring stand
▼Balance Adjustment
・Significantly strengthened mining power for Digtoise partner skills
・Fixed the abnormally high selling price of nails
・Significantly increased the number of police officers who appear when a crime is committed
・Added electric shock effect to Free Pal Alliance's crossbow
・Adjusted the flight distance of Sphere Launcher and Scatter Sphere Launcher.
・Increased the SAN value recovery amount of high-quality hot springs
▼Network Related
・Renovated the server lobby
・[Search by server name] will now work
・Added the ability to view online players on a dedicated server
*On community servers, this will only be displayed if the setting is enabled
▼Others
・Fixed the issue where Day 5 Memo was not placed
・You can now adjust the in-game brightness in the settings
・Fixed many minor bugs
・Corrected various incorrect text
・Improved measures against cheating
We will continue development placing top priority on fixing major problems and issues. Thank you for your continued support of Palworld.
https://store.steampowered.com/news/app/1623730/view/4165340162543998798
Update v0.2.0.6: Raid Boss “Bellanoir”! New content, improved building and more!
Steam version v0.2.0.6 has been released.
▼New Content
・Implemented the first Raid Boss
⤷ You can summon Raid Boss Pals by using slabs at the new Summoning Altar
⤷ Raid Boss Pals summoned by slabs are very powerful and can not be captured. Work alongside your base Pals to take on these powerful foes.
⤷ Pals Eggs can drop after defeating Raid Boss Pals.
⤷ The "extreme" version of the Raid Boss is incredibly powerful and difficult to defeat
・New "Training Manual" items have been added. These manuals allow you to give experience points to Pals.
・New item "Ancient Technical Manual" has been added. This manual gives you ancient technology points and can be randomly found inside dungeon chests.
・New "Recovery Meds" items have been added. Using these meds will slowly recover your HP over time.
・New item "Homeward Thundercloud" has been added. When used, this item will instantly move you to your nearest base.
・New item "Ability Glasses" has been added. When equipped, you can see Pal's stats.
・New stat boosting items have been added: "Power Fruit, Life Fruit, Stout Fruit". These items will boost Pal's stats when used.
・Added a new passive "Mercy Hit". Pals with this passive cannot reduce enemy HP below 1 when attacking.
・New item "Ring of Mercy" has been added. When wearing this ring, you cannot reduce enemy HP below 1 when attacking.
・New armour "Multiclimate Undershirt" has been added. Protect yourself against both the heat and the cold with just one slot!
・New building "Electric Egg Incubator" has been added. This incubator consumes electricity to automatically adjust the temperature to the optimum temperature for each egg.
・New building "Ore Mining Site" has been added. This mining site allows you to produce ores from the comfort of your base!
▼Pals
・Kelpsea can now produce Pal Fluids at the ranch
・Dumud can now produce High-Quality Pal Oil at the ranch
・You can now reduce the weight of metal ore while riding Surfent Terra
・Increased the amount of ore dropped while riding Astegon
・You can now raise Pal's rank to the maximum with a single synthesis using the Pal Essence Condenser.
(Condensation progress is now accumulated in the individual Pal)
・Negative Pal status will now be resolved after spending some time in the Pal Box
▼UI
・While aiming a sphere, it will now display how many of the target Pal has already been captured
・You can now check the cooldowns on partner skills for all your Pals on the main screen
・Equipment and item stats are now visible on the technology screen, even if you have not unlocked them first
・The tutorial has been improved and renamed to "Journey"
・You can now show/hide the "Journey" in the game options
・Damage number display size can be changed in the game options.
(In Raid Boss battles, the damage numbers tend to overlap a lot and it may be difficult to see, so we recommend adjusting the size)
▼Player
・Items dropped by players after death on a dedicated server can now be picked up by anyone after 24 hours of real-time have passed
・Added a new "sleeping" player emote (edited)
▼Base Related
・You can now allow/disallow certain work for base Pals at the Monitoring Stand
・Chest filters have been added. Select item types to allow or disallow inside chests
・Crafted items are now transported from crafting facilities. Selecting "allow transport" when crafting will result in Pals transporting those items to chests when finished
・You can now edit your character's appearance at any time by using the "Antique Dresser"
・Building and building piece placement rules have been relaxed
⤷ You can now connect stairs facing upwards
⤷ Roof pieces can now directly connect to foundations
⤷ Triangular walls can now be connected to stairs
・You can now force a Pal to work and cancel their break by picking them up and throwing them towards a facility
(Pals recover their SAN while taking a break, so be careful!)
・Fixed assignments remain fixed, even after bad events occur. Previously, some assignments would change due to certain conditions, but now they will remain fixed unless the Pal is placed inside the Pal Box
▼Balance Adjustment
・Minimum heat and cold resistance have been added to various armour. You will no longer need to take off your heat-resistance armour when it is cold at night in the starting areas!
・Reduce the button press time in the egg incubator
・Change the pattern for Jormuntide Ignis to something more unique
・Added legendary blueprints for some firearms (Dropped from specific enemies)
・Corrected the selling price of diamonds
・In single-player, it is no longer possible to select the initial spawn point for multiplayer
・Blocked the back of the starting area with rocks to prevent players from getting lost or stuck
・The increased attack power multiplier of partner skills that increase the player's attack power while riding has been uniformly reduced from 2.0 to 1.2
・Eggs now have a small chance to produce Alpha Pals
・Flying and floating Pals are now immune to falling damage
・Shop price adjustments
▼Bug Fixes
・Fixed a bug where treasure chests would become empty when dying in a dungeon, etc
・Fixed an issue where the effect that increases the player's attack power while riding was duplicating and accumulating under certain conditions
・Fixed an issue where players were not receiving loot when capturing Pals while mounted
・Adjusted the HP of the Legendary Pal and fixed an issue where the difference in HP between the captured Legendary Pal and the bred Legendary Pal was too large
・Fixed an issue where Pal would eat while riding.
・Fixed an issue where spheres thrown close to wild pals would not hit and be lost
▼Others
・Improved various Pal models and textures
・Added and adjusted some sound effects
・Many other minor bug fixes
▼Dedicated Server
・Fixed an issue where sorting did not work in the server list
・Improved the server list to allow page transitions
・Dedicated servers now support various log outputs
・Implemented REST API
※ Please check the tech guide for details
https://tech.palworldgame.com/
▼Cheat Prevention
・Fixed a vulnerability that allowed Steam account spoofing
・Fixed 7 other critical vulnerabilities
▼Soundtrack
・One new song has been added to the soundtrack. If you have already purchased the soundtrack, please update and enjoy the new song!
※ Please note that the soundtrack may take a few days to update
We are planning a larger, more content-packed update for summer 2024.
Enjoy never-before-seen scenery and thrilling adventures on a new island, home to many new pals.
In addition, we plan to add a large amount of new content including new buildings, weapons, and tower bosses.
It was only a matter of time.
https://www.nintendo.co.jp/corporate/release/en/2024/240919.html
I mean if they're worried about similar designs, maybe they should worry about how close they are to Dragon Quest... which was out like decade before than Pokemon
So far from what I'm reading, all we have is vague claims of patent infringement along with the info that Nintendo likes to sue and is rarely if ever losing their court battles.
Palworld's Terraria collab update is live.
▼Terraria Collab!
・Terraria Dungeon
⤷ A unique dungeon featuring enemies from Terraria has been added! Collect materials in the dungeon to create equipment from the world of Terraria!
・Terraria Equipment
⤷ 6 new weapons and 7 new armour pieces from Terraria have been added!
・The terrifying "Moon Lord" raid boss has appeared!
⤷ The Moon Lord has invaded Palworld! Work together with your friends and Pals to defeat the greatest threat the islands have faced!
▼New Content
・PS5 Dedicated Servers!
・Fishing!
⤷ Craft a fishing rod and bait to catch new Pals! To start fishing, cast your rod in water where you can see fish shadows.
・Salvage System!
⤷ Ride on water Pals and use the fishing rod to salvage supplies at sea! Collect new ores salvaged from the ocean floor to strengthen your weapons.
・New Islands!
⤷ Three new types of islands have been added to the world: Tropical Islands, Iceberg Island, and Shipwreck Island! Find new Pals that live on each of these new islands!
・Mission System!
⤷ You can now find and accept missions around the Palpagos Islands. Help the islanders and get rewards!
・Zoe's Special Mission!
⤷ By completing missions for Zoe, you can earn her trust and recruit her as an ally!
・Pal Trust Mechanic!
⤷ The more time you spend with your Pal, the more trust you will gain, and stats will be increased. The weaker a Pal's original stats are, the greater the trust adjustment will be, so even weaker Pals will be able to shine!
・Sleep together with your Pals!
⤷ After a hard day of farming and battling bosses, you and your Pals can take a hard-earned rest together!
・Treasure Maps!
⤷ Use treasure maps to find the location of the hidden treasure and obtain valuable items!
・Enemy Bases?!
⤷ Enemy factions now build bases just like players! They are on high alert and will defend it with their lives, but if you manage to raid them successfully, you can obtain new blueprints for buildings related to that faction.
・Settlement Overhaul!
⤷ We've made the settlements larger and feel more lived-in! There are also many mission NPCs now to meet.
・Player level cap raised from 60 to 65!
・New Buildings!
⤷ Pal Surgery Table - By using various implants, you can overwrite your Pal’s passives! You can also change the gender of your Pals here!
⤷ Fishing Pond - Relax and catch some fish in the comfort of your base.
⤷ Hexolite Quartz Mine - Well, you knew we would add this one eventually!
⤷ Large Incubator - Hatch multiple eggs at the same time!
⤷ Palbox Control Device - A terminal that allows you to access your Pal Box from anywhere in the base. It makes Pal swapping during raid battles more efficient.
・ New Building Material - \[Clean]
⤷ Decorate your base with futuristic floors and walls with this new building set!
・New Mechanic - Turbulence
⤷ Find unusual air turbulence around the world and use it to jump high into the sky!
・New Weapons!
⤷ Charge Rifle
⤷ Energy Shotgun
⤷ Overheat Rifle
⤷ Boost Gun
⤷ Pal Recovery Grenade
(These two are weapons for tamers who want to support their Pal!)
・New Item Types!
⤷ Whistles and Growth Acceleration Bell have been added!
⤷ New food recipes.
▼Arena
・A single-player challenge mode has been added!
⤷ Raise your rank by facing off against the fierce warriors of Palpagos Island! Get various rewards with the battle tickets you receive when you win!
・You can now set rules in the arena, such as banning certain pals.
・A public Pal Box has been added at the entrance to the arena that all players can use.
・An arena spectator function has been added in multiplayer!
▼Mechanic Adjustments
・Added equipment durability to the game settings.
・When a cooling Pal is assigned to the flea market, food spoilage rate is now reduced.
・Lyleen’s ability “Bountiful Protection” now recovers HP for all allies within range.
▼Balance Adjustments
・Some aggressive enemies have been made friendly.
・Pal skill cooldowns will tick down even if they are not summoned.
・The speed and stamina of Pals that can be mounted have been adjusted, and the speed of some Pals that were too slow has been improved.
・The lineup of bounty hunters has been expanded.
・With the implementation of the mission system, the rewards obtained from NPCs have been adjusted. To maintain fairness, conversation logs with all NPCs have been reset so that rewards can be received again.
・Pal Condensation is considered end-game content, so the strength of Axel, Marcus, and Victor on normal difficulty has been reduced to reduce its necessity.
・The power of some active skills, such as Pal Blast, has been increased.
・The probability of getting books that enhance Pal's work aptitude from attribute treasure chests has been increased.
▼Pals
・New Skins!!
The results of the 1st year anniversary popularity poll have been decided, and three new skins have been added to celebrate these results!
(※You must own the Pal to equip the skin)
⤷ Crown Chillet
⤷ Cyber Jetragon
⤷ Desert King Anubis
・Pals can now swim!
⤷ Swimming motions and animations have been added for Pals, and their speed in the water has been adjusted.
・New Water Skills
⤷ Geyser Gush
⤷ Aqua Surge
⤷ Torrential Blast
⤷ Hydro Slicer
・New Grass Skills
⤷ Crosswind
⤷ Reflect Leaf
・New Ice Skill
⤷ Freeze Wall
・New Unique Skills
⤷ Hydro Spin
⤷ Thalasonic Laser
⤷ High Breach
⤷ Lantern Sweep
⤷ Scorching Lantern Sweep
⤷ Smoke Jet
⤷ Trigger Happy
⤷ Chaotic Spray
⤷ Konoha Flip
⤷ Deep Breath
⤷ Dash Kick
⤷ Thunderslide
・New passive skills have been added!
▼UI
・Implemented "Easy Bulk Storage" feature! Conveniently store all materials in any chest around your base with the click of one button!
・Changed specifications to automatically select materials in bulk in the Pal Condensation UI.
・You can now set and quickly select your current Pal presets from the Pal Box UI.
・All neutral enemies now have green HP gauges, and only aggressive or hostile enemies have red HP gauges.
▼Multiplayer
・Fixed a bug where the option to display servers with matching versions was not working.
▼World
・Added more patterns to random dungeons.
・Fishing spots where fish shadows appear have been placed all around the world.
・Salvage spots have been placed out at sea.
▼Achievements
・Several new achievements have been added.
▼Bug fixes
・Fixed a bug where Jetragon would jump too high when jumping.
・Many many other minor issues have been fixed.
1.0 is out. Almost hit 1 million Steam users on release, down from 2.1 million on early access release. I haven't played in a couple years, but I started a new world to check it out to see if I'm still interested. Definitely had some bugs the last time I beat it.
I've been no life-ing this shit for the last week. It gets kinda grindy but it's fun.
