Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Yeah,
A copper or copper injected HS is meant to draw heat faster and aluminum is meant to dissipate it into the air faster.. Covering them with paint is going to negate either from doing their job efficiently at ALL.. long story short, BAD IDEA!!!
If the HS is pure aluminum you can get it anodized like what they do to paintball guns.. Its the art of bonding ink to metal using electricity, but it would still decrease the efficiency by some degree.. hope that helps..
