Padded bag that fits SG07?
lvyelion
I'm about to travel with my beloved SG07. I need a padded bag I can bring on a plane (in cabin ofcourse), that holds my SG07, keyboard, mouse, Bose music monitor and all the cables.
Both the SUGO pack and LanGear pack are bit too big, they are more for m-atx cases.
After some search I can only find some range bag (that carries your firearm to a shooting range) fits.
Are there other suggestions?
Dimension SG07
222 mm (w) x 190 mm (h) x 350 mm (d)
Breakout the sewing machine! Cause I don't see anything out there in the webs either.
would be very interested in one of these too, when i travel i will remove my psu and put it in my main luggage, make the sg07 abit lighter and easier to carry...
don't need to remove the PSU o.0, just use a good duffle bag or a duffle with wheels and some padding (like a towel).
problem is ive got a very cheap flight so hand luggage allowance is only 7kgs...don't know how strict they are but i'll take it out just in case they don't let me on the plane, that way i wont have to open up the pc at the airport and have suspicous security guys haul me away lol
I'll second the sewing idea. Pick up some black canvass and some .5" foam, and it is pretty easy to stitch together some sort of case.
I did a custom case for my monitor that fits inside my carry on. I'll also travel with a full computer in a cardboard box case, with power supply done externally. (Mostly to get it flat enough to fit everything) Been experimenting with a couple power supplies and small form factor motherboards, and will pull out the wood/welder now that the snow is gone.
TSA really don't care about the equipment. I do it every week.
Id check out the RUSH 24 by 5.11, Its a full lan back pack, fits the sgo7 keyboard mousepad mouse headset switch extra network cables and surge protector. And it feels great on your back with all that weight too, which most packs will dig in or just stress you out after a while.
Works great for paintball or anything else that might come your way... zombies...;)
http://www.511tactical.com/All-Products/Bags-Backpacks/Packs/RUSH-24-Backpack.html
