P5WDG2 WS PRO
A quick question on some settings in the bios :
Can i disable "Marvell SATA Controller" ? I only use one hard drive.
I would also like to disable one of my Lan ports in the bios and i have two options for it:
1) PCI-E Lan
2) PCI Lan
Wich one should i disable?
Yes, you can disable the Marvell SATA controller.
You can always use trial and error to figure out which Lan controller you need to disable.
I believe the PCI-E Lan is the TOP ONE, (closer to the mouse and keyboard ports)
