P5W64 WS Pro locks up in CMOS setup....
aamsel
I have a P5W64 WS Pro that locks up in CMOS setup. Basically, using any keyboard, USB or PS/2, I go into the BIOS settings, and within a few moments or so, the system locks up, usually before I can save any changes that I have made in the BIOS settings.
Anyone else seen this and/or know of what is causing it, or any possible fix???
Thanks a lot!!
Andrew
from the main menu quickly "load optimum defaults" and save and exit.
that should stop it, now you can go back in an methodically make your changes and test to do whatever it is you are trying to acheive. apparently you have something not correctly set.
