P5W Overclocking
paddi70
Hi, noobe here and would like some advice. Have just crossed over from AND 4800 X2 to C2D, as i couldn't get on with the X2, kept freezing up the system. Sold the lot on fleebay and now have a new system that I'am very happy with. specs below.
Running the Asus software were clocked at 2425= 346 x 7. With CPU temp of 28, hitting 34 when gaming.
Now i would like to clock some more from the Bios but unsure fully how too, all advice welcome
You need to reduce the memory speed and then shoot for more on the FSB. You already have a good starting point with what the Asus panel tells you. You might also want to up the MCH voltage to stabilize your OC.
I think your corsair needs 2 volts to run at 6400 speed, we locked PCI express at 101 and PCI at 33Mhz
At CPU all should be disabled except Microcode ...
These are for my ram settings 4-4-4-12 at 400Mhz maybe your corsairs are 5-5-5-15
You should be getting easily to 2800mhz with your E6300, thing is you set your bios screen like I did, maybe a bit more MCH voltage 1.6 or 1.65 ( first screen) is required my P5w was happy with 1.55. I would work in small increments regarding the CPU frequency, test it thoroughly with Memtest ( ram test) and Orthos blend in windows to ensure stability...
Watch those temps though !!!
let me know if it helped Paddi, remember though go in small steps and remember not all hardware OC's aswell and plz monitor temps via eg Coretemp ( reeads core temps , shouldn't exceed 60°C for safe 24/7 operations) these temps will be higher than the readout in bios or Asus Probe
Here is CPUZ reading, so all happy. many thanks. need to full memtest and started Orthos, just to see and temp went up to 51.
So far so good, full tests tonight and tomorrow.
Nice...how high on the MCH voltage did you have to go to get 400mhz stable?
Looking at water cooling, as a stacker case has come on fleebay that I'm interested in. Already have a swiftech 220 kit around here somewhere. Help with the temps a bit.
You can add a small fan to the northbridge if you want, a 4cm fan will do fine and reduce temps there over 10-15°C keeping it stable.
Just remove the Asus cap and screw the tiny fan on there...
Do you have the option on your motherboard to go higher than 1.65 , mine was of the first realse maxed out at 1.65MCH, newer boards got 1.85 but I've heard they backed it down....
Well if it's happy at 1.65 mate leave it there but think about the fan on the northbridge !!!
see my piccie :
Yeah will fit one, have you placed it directly over the heatsink. 1.65 good or could I go higher with better cooling?
you can go slightly higher, but many 975 boards and surely the P5W has a limit around 430FSB, also note you are still on 1066 strap once you go over 400FSB you will enter 1333 strap which gives a higher latency at the NB memory controller thus reducing memory performance, in overal lesser performance even with higher CPU speed.
Stick with 400Mhz, and enjoy your system, it's the fastest clock for clock, if you want to go higher buy another type of mobo based on 965 chipset ...you are pushing your system far enough already for 24/7 use...
and you saved yourself loads of cash , performance between E6600 and E6800 mate , great stuff he !!!
I'm doing detailed OC testing/tweaking on this board (with a qx6700 mind you) have lots of time so I'm doing a write up. If you're interested its over in the cooling/OC'ing section.
leeghoofd thanks for the screen shots!
I followed everything except for increasing the voltage just because I'm afraid that I'm going to fry something. I did increase my ram voltage to 1.9 but do not know how much more I can go but I'm getting 2.9ghz with 4-4-4-12.
Can someone outline what are the safe zones, medium/testing zones and danger/red zones when increasing voltage?
Most memory will do 2.2V without too much problem.
Vcore - On air (depending on the cooler), I wouldn't go much over 1.375-1.4V on stock cooler, or over 1.45V in general even with good air cooler. I've never WC, so I don't really know what I'd do then. I think Intel said something like the absolute max was 1.5V with C2D, so somewhere between 1.5-1.55V on a good WC setup would probably be the max I'd do.
MCH - probably 1.65V unless you change the cooler or add a fan. Then the limit is probably not that big of a deal.
FSB termination voltage - don't really know. I just boost it up one notch and leave it alone.
Thanks! I'll try it after work. I think I might have to loosen the memory timmings to get at 3 or 3.2ghz.
Either loosen the timings or lower your divider a little.
Thanks kirbyrj,I loosen the timings, increased the voltage to 2.2 and it booted into XP w/o any problems. I guess the next step is to stress test it. Does everyone run their computers 24/7 OC or should I shut it off if OC?
It depends on how much you want to spend in electricity ;).
Did you get the sleep mode to work. My computer wakes up but my monitor does not turn on. Kindof weird unless I have to adjust something in the bios.
I've never tried it. I don't have Windows set up to hibernate after a set time. I usually just shut the monitor off and go to bed :).
I was overclocking my P5W DH to 3.6 GHZ, and I couldn't get it stable until I turned the MCH up to 1.75 volts.Whenever it wasn't getting enough power my system would flat out lockup and I would have to manually cut the power to get it back up and running. Is this particularly dangerous, why did I have to bump MCH up so high? Could I alternatively just bump the Vcore up to 1.5 volts or something? Just making sure I didn't screw up here.
MCH controls the Northbridge voltage. I guess your board just needed that much voltage to hit the high FSB. It's really no different than with your VCore. Sometimes your northbridge just needs a little extra juice to hit higher numbers.
