P5N32E Plus vs eVGA 680i
TigerLord
Any thoughts?
The eVGA is a little more expansive. I heard the P5N32E Plus has issues withDDR800 chips, among others.
I do plan on oc'ing ... but which one is the best for a dual gtx setup?
Both will perform similarly. I would go with the eVGA variant since it uses nVidia's reference design and comes with a NB fan.
The 680i chipset costs more to get from Nvidia which is why even the eVGA board is more expensive than the Plus. I'd probably get the Plus partially because it's based on the same motherboard as the Striker and has higher quality components. eVGA has a nice warranty policy and has done a good job of advanced replacement, especially with the quad core fixed boards. My personal belief is that the Plus is a hybrid chipset like it is to address the issues of overpriced x16/x16 SLI boards and some of the bugs inherent in the chipset. Asus tends to have a pretty good record of timely bios fixes also.
Trust me the PLUS doesn't have anywhere near the problems the 680i does. If you visit the official forums there is a thread going about what ram works with this board and there is a very wide variety of sticks being reported as working without problems. On the other hand visit the evga boards and you'll see the exact opposite. Many are reporting that 2.2v ram and above is only lasting for 90 days or less in the evga board. There is a monster 26 page thread on the official forums about it. Heck there are some people who can't even get their boards to boot unless they first use a cheap 1.8v stick of ram just so they can get into the BIOS.
As far as performance. Every review I have read shows that the PLUS board is exactly on par with the 680i board. (Just google "ASUS P5N32-E SLI PLUS review", there are 4 or 5 reputable reviews out there including one right here at [H])
I have a PLUS on the way from the egg right now so I'll be able to tell you first hand later this week.
if you want a top of the line, bleeding edge tech, then the EVGA 680i is for you. if you want a stablized board that has had its time to be perfected, go with the plus. in time, the evga 680i will iron out its problems jsut like any other mobo. it is noted that EVGA has superb customer service, they replaced all our old mobos which had a quad core design flaw for free :)
Ive asked around a bunch of forums and I have as many votes for the evga than the p5ne plus ...
The EVGA is easier to find around here than the Plus, albite a little more expansive...
Am I to understand the only known issues with evga is sata and ram ?
it is fixed already... i personally didnt have any problems even with the default bios that came with the board.. eVGA now has P25 bios which i heard is quite good and stable.. i am using the P24 bios. no problems no sata problems nor ram.... oced my e6600 from 2.4 to 3.6ghz on air.. no problems at all.. very good board.. built very strong and overclocking is easy..
The sata problem was fixed before xmas last year. However there is ongoing problems with ram (especially 2.2v and above) as well as an abnormally high amount of doa boards.
I strongly urge you to visit the official evga forums before you decide to pull the trigger on an egva board. There are many people even around these forums who are on their 3rd and 4th rma with these boards.
one thing i have to mention is that while you may see alot of posters with problems on the board, there are hundreds more that have not had problems and have things working just fine. you have to take it all into perspective :)
eVGA is a much better board, support is incredible for evga, ASUS support sucks big time, plus all of their boards have vcore issues, with vdroop big time.
most vcore issues are gone with the new biosses for all Asus boards, both boards will perform similarly, but do you need SLI ? if not go for the excellent stable 975 or 965 intel chipsets. These are easier to setup, are very very stable and cost less...
You have to go what ya heart tells yah , sounds stupid but it's like that, I have had all these boards (P5W, P5B dlx, EVGA and now Asus Striker) some users post comments based on rumours or probs from eg half a year ago and it's really hard sometimes to find ya answer in all of this....
Go Intel if ya don't need SLI
If you need SLI go with EVGA (I would do it just for the lifetime warranty mate) but I tell you again these boards are not easy to setup and some expertise and loads of patient are required to get them goin !!!
