P5N32-SLI Premium Lockup
Hello everyone. I purchased the Asus P5N32-SLI Premium WIFI/AP board a while back and have been having problems with it ever since. The computer locks up in-game; randomly. I have gone through many processes, including replacing the graphics card, etc. Strange thing is when I leave the side door off, the computer is fine. Leading me to believe it is heat related. The CPU temps are all within acceptable range, and the power supply is an antec trio with 3 12v rails. So there should be no problem there. I have noticed though that the northbridge gets REDICULOUSLY hot during gameplay. I am all out of ideas and may end up having to RMA the board which would be terrible since its my only computer at the moment and I'm right in the middle of starting a new college semester :(. Any help would be appreciated.
~ manofmandango
- P.S. - Also, I recently got a Logitech G5 mouse, which worked fine for the first few days but now it intermitantly turns off and then is re-recognized by windows/motherboard. All drivers and software is installed correctly.
It might be that the northbridge heatsink isn't making good contact. You could try taking it off and remounting it with new thermal paste if you're into that or just getting a different one. But it does sound heat related.
Reseated the northbridge heatsink and replaced the pitiful thermal grease with some arctic silver 5. Hopefully it'll fix it.. I doubt it though. We shall see.
Well, if you have a spare fan around, you could try mounting it near the heatsink to blow air around the northbridge.
Hrm... Here's my thing. I shouldn't have to if the product works as originally intended. Aside from the fact that I have 4x 120mm fans in the case (P180B). I may end up just RMAing it.. :(
Yes, but I was more interested in seeing if your northbridge heating up is really the problem. It might be that, it might be something else. RMA is always an option too :).
The thing is, I've just started a new semester at college and this is my only computer. If I chose to RMA I would be without any median to do my work on. And being an IT major.. I couldn't have this so I was just hoping to try to find a solution before RMAing. I'm sure you understand.
Get an Antec "spot fan" and shoot it on the chipset
Edit: Shoot it all over the chipset. Just shoot it man.
Doesn't work. I don't know what else it could be.. Possibly the memory (OCZ) and possibly the power supply (Antec TruePower 3.0 550watt) if its not the motherboard... Anyone else have any experience with these products?
Maybe its the PSU that is overheating? (ie northridge maybe hot to the touch but not showing out of scope high temps, the fan you set up blowing into the case was possibly cooling the PSU since you have tried giving the Northbridge its own fan).
What are you memory timings/voltage set to? It could be that they are ok when you have cooling in the area, but when you don't, they overheat just enough to be unstable.
I have them on the default. Haven't done any sort of overclocking. I know my particular memory runs at 2.0v, so I've tried in the past to run it at such and it still locks up.. So I'm not sure if this is still a problem.
Try loosening the timings to something like 5-5-5-15 with 2.1V and see if that helps anything.
I have this same problem with my P5N32-SLI Premium board with OCZ memory.
I'm pretty sure it's the memory that is causing the problem. I did the Prime95 tests on the cpu and it never had a problem even after running up to 65 degrees C. But soon as I start a memory test, it freezes.
I found my answer by slowing the memory speed down in the BIOS. At 800Mhz I could freeze the system in 10 minutes. At 775Mhz I could last about 3 days. I've currently got it set at 750Mhz and it's been stable for three weeks now.
I've tried various memory latency settings to no avail and checked voltages. The only thing that's helped me is to slow down the memory speed. Which is very annoying since this board is supposed to be overclockable.
Specifically, I have the OCZ Gold Gamer exTreme XTC memory. OCZ is not listed in the motherboard manual as appropriate memory to use with the board. I would have returned it, but I had already sent for the rebates. :(
I have all the default settings except for these.
The memory latency settings I have are 5-5-5-15-auto-auto.
Under Jumper Free -> Frequency Control I have
  • System Clock Mode: MEM Precision Tweaker
  • New Mem Speed: 750
Under Voltage Control
  • Memory voltage: 2.00V
I just got this mobo and have 4x Corsair XMS2. I'll let you know how it goes...
For those that have it running good, do you like this board?
I'm wondering if this is my problem. I just built the rig in my sig. The mobo isn't the premium version but it is the P5N32-E SLI and my memory is Corsair XMS2 PC2-6400. I've been having completely random freezes since I built it and I haven't been able to figure anything out to resolve the problem. I used to think it was a driver problem with Vista but I've had a few times when the system would freeze right at the screen where you can enter the bios.
I've been into the bios several times but I must be missing something because I never saw a place where I could adjust anything having to do with the memory, least of all it's speed. Does anybody know where in the bios this stuff is located at?
Also, does everybody pretty much recommend running something like Prime95 to test out a new system like this?
Thanks
I have this exact same problem as well but with an evga 680i motherboard (I have the same memory). I wonder if all 6x series nvidia chipsets have an issue with fast memory. I'll try lowering my memory rate and see what happens (also in vista..and I occasionally get the hang just after the bios boots as described above).
Sometimes the machine is stable for many hours..other times for 20 minutes.. It's not heat related...
