P5N32-E SLI not PLUS
gyranthir
Internet connection issue:
I am having an issue with getting my computer to connect to any wireless connection.
I have tried 3 wireless cards. A no name wireless card that I borrowed from a friend, it would see the network but not connect to it. (It worked just fine in my old computer).
I tried a $65 linksys wireless G card it would see the network but not connect. If i let it go until the monitor went into rest mode and the screen save (blank) would come on it would connect to the internet and i would hear my messengers and such all start dropping messages to me.
I would shake my mouse and begin trying to do stuff on the internet as my computer woke up and it would quickly lose the signal and drop offline.
Anyone had any experience with this or any theories as to why?
the 2 wired ports on my mobo work just fine.
My comp spec is in my Sig.
Maybe some random conflict with the Wireless Zero Configuration service. Did you try disabling it and using the utilities that came with your card? Do you have any WEP protection and did you input the settings on your computer for your wireless network that would cause you to see but not connect?
I put in all the network specs just like my other computer and it worked fine on my old one.
The weird thing is that if the monitor went into sleep mode and so did the video card (it seems) the internet would connect, but when I woke it up to actually use the internet it would quickly disconnect.
