P5N32-E PLUS - Specs released - NOT 680i
annoyed
ASUS have put up a page here:
P5N32-E PLUS
It is under the category of "NVIDIA Dual x16 SLI", which they helpfully explain is:
NVIDIA® Dual X16 SLI
(C55+MCP55P; a.k.s. nForce®650i SLI & nForce®570 SLI)
ASUS HybridUp Technology
I have had one for two weeks and now they release the details. They should have told people what this is and what it means for the end user before these motherboards became available in the channel. Even if it is at least as good as the old P5N32-E in every respect, they should have called it something else, to distinguish it from a 680i motherboard.
Only other difference from non-plus version according to spec is:
1. "Uses 100% High-quality Conductive Polymer Capacitors". This means it has Striker quality caps, as you could tell from looking at the board versus the Striker Extreme pictures.
2. They refer to Dual x16 anywhere the non-plus spec says 680i.
650i is a single X16 or dual X8 as is 570SLI.
So what they've done is put 1 of each on the mobo running in it's single X16 config & each connected to a different PCI-E X16 slot.
that's pretty much what C51D (A8N32, AN8 32X etc.) was - an nF4 chipset running X16 to 1 gfx slot & as southbridge plus a separate chip running X16 to the other.
Ok...fair enough, but what are the advantages of doing it this way? Is this a better board than the 680i version?
I guess that the component parts are cheaper - nVidia supposedly charges something like $140 just for the 680i chipset.
Apparently it reuses the Striker PCB too.
it won't have all the features of 680i but at least in the short run it may be more stable until 680i gets more mature
its 680i 100% driver for 650i not function on this mobo,only with 680i nvidia driver,its better than non plus.
pcb is striker extreme,asus wrong something with this mobo at chipset.Run great on my rig amount of 2 weeks
at 3ghz.syncron.In Roumania its expensiv 235usd +tva.P5n32e sli its 230usd+tva,not 140 usd.This price its foe p5nesli with 650i sli.
Bios its same with striker extreme.Conclusion is 680i,not 650i,not 570i,have 3 pciex,others not have this.
