P5N-E SLI Temp
haadij404
Anyone know where the temp sensor is located on the mothrboard? Mine gets pretty high, around 37c idle and when gaming it gets around 44c. My ambient room temp is 22c. I think this is on par with other folks, as the chipset gets pretty hot especially when overclocked. I am using Speedfan 4.32 to check temps. I am pretty sure the MB temp is Temp 1, although I am not certain.
What are your temps and what program do you use to monitor the temp? I am very interested in seeing other peoples temps.
No thats the 2nd one, 1st temp is CPU.
I use ASUS probe and Coretemp.
my northbridge idles around 32-34C, loads up to 35-39C
my southdridge is consistantly 25C, unless i'm doing alot of audio encoding. maybe maxes out around 28C
my CPU reads 30C while idling and has hit a max of 42 on a 16 player CIV4 map, near the end of the game when everyone is building nukes.
i use speedfan 4.32 and asus pcprobe2 as a comparison tool.
temp 1 cant be CPU temp - they have their own Core 1, 2 temp designations. The MB temp could be temp two. If it is, than I am happy. Its a cool 32c.
How do you use coretemp to monitor the MB temp? It doesn't say.
The easiest way to find your CPU temp in speedfan is to see which temp jumps the highest when you start running a CPU intensive app like Orthos. It'll jump 5-10C in 15 seconds.
