ShinaKitsune
- Nov 16, 2006
So I just picked up an e4300 and an asus P5N-E SLI motherboard.
So I was going to use my old Maxtor DiamondMax10 SATA HDD with it.
I get into windows xp setup and when it comes to the hdd it says that its not formatted (even though I formated it with the maxtor utility that came with the hdd as ntfs with default cluster size etc).
So I let windows setup reformat it, it goes through all that and does the first text-based setup fine (where it copies a bunch of files to the hdd). Then when it reboots to finish up setup in the GUI-based setup portion... it just hangs there with no error, just a blinking _ in the top left of my screen.
Now if I press F6 to install a 3rd party raid/scsi driver and then use the one off of the disk that came with the P5N-E it will see the NTFS format, and install to that. Will complete the text-based portion of that fine. Will also complete the GUI portion of the install, but then when it tries to reboot to finish everything off (the setting up of accounts, activation,etc) it will start to show the WinXP loading screen... but then it will eventually halt with an UNMOUNTABLE_BOOT_VOLUME error.
Now to see if the HDD was bad, I just tried installing WinXP onto it with my MSI RD480 Neo2-fi motherboard and etc and it went just fine....
This is also the 2nd motherboard that I have tried.
I am trying to use some Patriot (ddr2 667) ram, its not on the QVL from what I can tell, but it passes memtest and windows memory diagnostic just fine.
