P5E RAID 1 Problem
equate975
Hey guys, I am having a problem with a P5E board I just got running raid 1 with their ICH9R.
It started out just fine when I was building the computer, I then moved it to work and I think one of the sata cables wiggled off in the car. (I really hate their design where the cables go in sideways on the board, I always have issues with them not seating in all the way or coming off)
Anyways, I start the computer up (Running XP Pro with SP3) and it says the raid volume is broken and a drive is missing. I popped the cover on the case and saw one of the sata cables looked like it was off a bit.
I seated it back down, and after the POST when the raid manager will show me the volume/drives it shows my broken array and a "new" disk that isn't in it. When I get to windows that "new" disk is gone. It just shows I have 1 drive plugged in. This is on the newest Intel Storage Console program.
So I reboot, and I notice after the POST in the raid manager the drive is gone again. So I shut it off, play with the cables some more, flip it back on, and the drive is back. But when I get to windows its gone again.
If I reboot after this, its gone before windows. If I shut it off/unplug it (while off)/Switch the port, it will show up once before windows but when I get to windows its gone again.
I really have no damn idea whats going on. Bad Drive? Bad Board?
Any help would be great, thanks!
bad cables? power cable staying to the drive while you're wiggling cables?
