P5B/e6400 will not POST (Help!)
tomgrossi
Hi. I am building my first machine in a number of years and had forgotten what a pain it can be. I could really use my help. I selected the following components in hopes of minimizing compatibility issues and maximizing roeliability but no luck. The system just won't POST (I guess that's the term... I'm a real newbie.)
-E6400
-Antec Sonata II case with included SmartPower450 PS
-ASUS P5B (the "vanilla" version, not deluxe) - BIOS is whatever it is out of the box
-Corsair XMS2 5400 DDR2 RAM (2x1GB)
-Gigabyte 7600GS graphics card
-Seagate SATA drives
I've tried a bunch of different things but in *every* situation the same thing happens:
- The CPU fan, chassis fan, and drives will all spin up.
- There are no beeps whatsoever
- The screen stays blank (it thinks the computer is in power saving mode)
- The numlock light on the keybaord will go on and off when I push it
The first power up after each time I clear the CMOS causes the fans to spin for about 2 seconds, then everything goes off for a second or so, then it all starts up again and stays on. Any power ups not following a CMOS clearing does not have this effect.
I have tried, each with a CMOS reset in between:
- Reseating the RAM
- Using only on RAM stick, then the other
- Removing the RAM altogether (no beeps here, BTW)
- Reseating the CPU
- Reseating the graphics card
- Rechecking the connections
Again, never a beep or anything and I thought I was using pretty mainstream stuff. What should I try next. Unfortunately, I have no other DDR2 ram nor any other processor that fits in this socket so I'd really prefer to minimize what I need to buy just to test it out. Is there anywhere that doesn't charge restocking fees that I can return things to if they don't solve the problem?
Thanks,
Tom
The problem is usually with the power supply in the Sonata II's. They are notorious for failure and when I first started doing RMA, we had a stack of 10 in the back with dead power supplies. If the system doesn't beep at all, it's not RAM related. I was lucky to test the P5B with Corsair, OCZ, and Kingston, and they all appear to work well with it.
I have a multimeter. Is there a way I can test the PSU. What should I be looking for?
Discprencies in your 12v rail. That is one thing that I would look at. See if it drops below the +5/-5% tolerance when you attempt to POST the system. Looking at the 5v and 3.3v rails wouldn't hurt either.
Another thought is to check the connection to the 12v connector on the motherboard. Are you using the yellow/black connector from the power supply? It will either be 4 or 8 pins. I have seen people make the mistake of plugging in the connectors that are meant for video cards.
Thanks. I do have the right e-ATX power connector (I almost screwed that up though... luckily the other one didn't fit.) When I measured the rails they were quite solid at 12.23V and 5.03V. Another person suggested I may have too old of a BIOS version to support the Conroe chips but is there any way to flash the BIOS without POSTing?
I don't know who that person was, but it was a load of crock about Conroe support. *ALL* 965 boards have support for Conroe, some of the 945/975X boards on the other hand do not.
I've checked Corsairs' help forum and they suggest disabling legacy USB and setting the voltage to 2.1v. But then again, how can you do that when you can't get the board to POST?
I do have to admit that I personally come across situations where some kinds of memory will not allow a board to POST. This could be one of those situations. I've only been playing with the P5B for the past day or so and the only RAM I used was OCZ Plat. XTC PC2-6400.
Worse case scenario is that you may have to return the RAM for something that works. Speaking of Corsair, I have a dead set of XMS2 PC2-6400 on my bench. :p
Rule of thumb right now is to avoid any kind of memory that has Micron D9 modules when using a 965 board. The problem with that is 90% of all DDR2 memory uses Micron, go figure.
Do you have voltage hungry memory? Might need more than default voltage to run at the By SPD timings.
I had specifically chosen teh Corsair XMS2 since the P5B is known to be finicky and people on other boards had mentioned they ahd had the most success with the XMS2. The other thing that confuses me is that I don't get a beep even when I remove the keyboard and all the RAM from teh sockets... if it was the RAM that was the main culprit, shouldn't this at least cause an error beep?
Update: as a test, I disconnected everything from the motherboard except the CPU, power, and the case speaker (i.e., no RAM, no grpahic card, no drives, ...). No beeps. Does this mean the motherboard is liekly bad or is that jumping to conclusions?
just a shot in the dark, did you plug in the 4pin aux power from the power supply to the motherboard ?
(sorry dont mean to insult you but several years ago there was no such thing needed and just want to make sure.)
No insult taken. I'm sure that if it's not a dead board it's something that simple but unfortunately the 4-pin power connecter is connected and seated well (when I take it off, the board won't even spin the fans like it does with it connected).
looks like you have thought of everything so lets grab at a few straws. on the psu on the back has the switch been moved (under the on/off switch)? I have seen those for some reason get moved and cause the EXACT same problems. Before RMA'ing anything, is the BIOS chip socketed, if so you may be able to get Asus to send you another BIOS chip. A bad BIOS chip will not allow a post. Other than that I have also seen instances where if you have something out of place hooking up the case to the mobo or a jumper setting causing the same probs.
