P5B-E or P5B-Deluxe?
kent
Which should I get?
I'm just doing a simple overclock to 3.2GHz from 2.13GHz (E6400) with some DDR2-6400 (PC2-800) RAM
I like the look of the Deluxe better, I like the factory heatpipe heatsink better as well and the extra $30 doesn't bother me.
Is there a reason I oughta get the E over the Deluxe?
I just bought an Asus P5B Deluxe wifi edition. This board uses the same bios as the P5B Deluxe and is identical to the P5B Deluxe except for the add on wireless card.
I had a few pains with it at first but I've found ways around the problems now and it's working good.
I'm also using an E6400 and at default volts for everything it runs at 400 x 8 with ease. I'm presently at about 413 x 8, still at default volts but I haven't tried a good long Orthos run on it yet. It has gone as high as 450 x 8 = 3600 MHz but it takes a pile of volts to be stable up here.
For a few extra dollars I think it's a good idea to go with the Deluxe over the P5B-E.
I liked the previous Gigabyte DS3 I built for stability but I needed firewire for this build and the heatpipe cooler on the P5B Deluxe is way better than the big ugly cooler on the northbridge of the DS3.
I can't think of any reason why you would want the E over the Deluxe :)
The Deluxe is worth the extra 30$, because of the Dual Ethernet ports and better chipset cooling.
They both clock similarly.
I'd have to agree with the cooling part, but the dual Ethernet ports aren't all that useful unless you plan to use your computer as a router?
Well, if you've got more than 1 computer in the house and want to do a really quick transfer... Or, say you still want a wireless router... Have XP share it's internet to the other port which can be distributed however you like.
It's really useful, I find, when moving large documents between my desktop and laptop... Just search for the desktop under "My network Places" and copy at 28mb/s with ease.
Never thought of that - good idea! :)
Unclewebb, great to see you again. You were a wealth of help when I was still on my S754 system (which I still have!)
At any rate, my only concern was the Deluxe would not clock as well as the -E.
My only other question is, is the Deluxe's main PCI-E slot the 1st or 2nd slot on the back of the case? I have an Antec 900 and am worried about the issue that case has with the 1st slot.
Also, will this board install Windows from SATA optical drive??
I would go with the P5B Deluxe, it gives you more features and it OCs pretty damn good out of the box. The P5B-E is a good choice if you plan on doing some mods to it, since it only gives you 2.2v max for your memory. Both mobos will let you install Windows from the a SATA HDD. I've owned both and obviously I kept the better one.
How about the first (blue) PCI-E slot
Is it Slot #2 on the back of the case, or Slot #1.
If it's Slot #2 (I believe it is, just need someone to confirm) I'm IN
The Blue PCI-E Slot is your fist slot (16x) then Black PCI-E Slot is your second slot (4x).
No no no. Sigh.
Is the blue PCI-E slot Slot #2 on the back of the case.
Remember back in the day when you'd have AGP and 6 PCI slots.
AGP = Slot 1 on the back of your case
PCI 1 = Slot 2 on the back of your case
PCI 2 = Slot 3 on the back of your case
What SLOT ON THE BACK OF THE CASE, is the first PCI-E slot??
Just count from the bottom on the board. ATX mobos are set for 7 standard slots.
-bZj
Dude, seriously.
Can you tell me if the first PCI-E slot is #1 or #2 on the back of the case or not?
Dude, seriously.
I think I understand what you're asking, but doesn't this depend on the case? For me, I'm pretty sure it was the 2nd slot - but will have to confirm when I get home.
THANK YOU.
The P5B-E clearly shows it as the second slot because the first slot is a 1x PCI-E slot.
I have the Antec 900 case which has issues with motherboards using the first slot on the backpanel for graphics cards.
The P5B-E and P5B-Deluxe boards looked very similar, but the Deluxe is missing the 1x PCI-E slot on top. That's why I was concerned about this issue.
I have the Asus P5B Deluxe. I highly recommend it if you are interested in overclocking. I got my E6600 at 3.4Ghz. It's a very stable board and i have not had any issues with it at all.
If money is no option, P5B Deluxe for sure.
If "money is no option," I'm curious how he would purchase a motherboard at all.
Anyway, the primary reason to choose the Deluxe would be that it is an 8-phase power design and the P5B-E is not, so the Deluxe will run cooler while allowing higher clocks.
And dual ethernet ports, more SATA slots and a better cooling config :D
Ooh, and a sexy black (non puke brown) PCB.
just for reference w/ the Antec 900 case owning it, although my graphics card goes into the second slot, if yours does use the first slot, and you have the problem w/ the DVI port, all you have to do is dremel out a small section of the slot cover and you're all set.
"If the cost of the motherboard makes no difference in the decision making process" is what I should have said :p.
Stupid question: how do you remove the optional fan? The technician plugged it in and I'm having trouble taking it out.
definately go with the Deluxe over E. also GPU definately goes in the second slot.
You guys rule. Thanks.
Will be ordering a Deluxe this weekend
Just what you need, MORE SATA plugs :p
The P5B-E has 6 + 2 + 1 eSATA. How many do you need??? :p
