P5B-E Mobo not booting
Frosteh
I've just installed the P5B-E into my computer, along with a E6600 and 1Gb stick of OZC PC5400 RAM.
It's not booting, it powers on with my 7950GX2 plugged in and 1GB of memory in slot A1,it doesn't give an output to my monitor or give me any BIOS beep codes.
Can anyone help?
*edit*
All 3 power connecter are in, 7950GX2 has external power, all fans are running.
I get BIOS beep code with no RAM installed but nothing with RAM inserted:(
Theres nothing on the monitor (I have one plugged into each output for my video card just in case) I dont have anything else plugged in (keyboards, mice, hard drives, floppys or CD/DVD ROMS
when I was looking at the 7950gx2, i didn't see the p5b series on the approved motherboard list.. have you tried any other video card?
No, I don't have any other PCI-E video cards available for testing, only AGP
The other strange thing is that when I first power on the system after completely disconnecting the motherboard it sends power to everything just fine.
But after holding down the power button to turn the system off, and then attempting to turn it on again, the fans spin up for 1 second or so, then power off, then after about 1-2 seconds the system powers on again and everything spins up.
It wont boot in either case, but it's really strange.
I really want to get this up and running before xmas, can someone please give me some help with it, im running out of ideas.
Does anyone know if the 7950GX2 can boot with this board or will I need a different video card?
*edit*
The above question applies to stock mobo BIOS, I know theres fixes for the 7950GX2 in "recovery mode" but I assume it should work normally otherwise there would be a fix specifically for that.
What the hell is "recovery mode" anyhow?
Thanks for your input, that 2nd link is actually a thread I started LOL
checking back on it, it seems we can eliminate the video card, must be the RAM then.
Yup, i grabbed a stick of 256Mb generic RAM from a Mac at work and it's booting fine.
Updated the BIOS but nadda, changed RAM voltages/timings and nadda, i've orderd some Crucial RAM which is tested with that board, I should have never strayed from crucial it wasn't worth all the BS and time this has cost [edit] "costed" LOL [/edit] me.
Anyhow 1-2 day delivery, most likely the 26th or something at this rate, SIGH :(
I went with corsair.. booted up no problem.
i think the P965 chipset needs RAM that has JEDEC compliant settings. (1.8V)
