P5B Deluxe no worky
Ooddiittyy
The rig:
P5B Deluxe
Intel Core 2 Duo E6600
2 gig Corsair XMS2 Twin2X DDR2 800
2 SATA II Seagate 320
Antec SmartPower 2.0 500W PSU
EVGA GeForce 7600GT
Misc. other crap (not connected at the moment)
So this is driving me crazy. I bought the board and everything, set it up, and it didn't work. I guess it's giving me a POST beep, but it's quiet and I can't be sure. It's definitely not giving me any other error beeps, though, but the monitor isn't receiving any signal. I RMA'd the board, got a new one, and guess what? Same thing. The folks at ASUS have alternately told me: there's a BIOS update that the board needs to accept Core 2 Duo; there's not a BIOS update needed; there might be a BIOS update needed.
What I've tried:
reseating CPU, RAM, video card.
tested video card on other system; tested other RAM in my machine, both work
bought crap Celeron CPU to test with, still didn't work
reset CMOS
Either I'm being really fucking stupid and missing something completely, mind-numbingly obvious, or I'm up shit creek without a paddle, and I forgot my snorkel.
Anyone have any suggestions from prior experience or just general coolness? Send 'em my way!
Cheers
Ooddiittyy
your just a stupid terd sucker!!!
haha jk
help graham out!
i told him that i believe it is a bios issue
I've posted last night about my EPoX motherboard having similar symptoms after i received my repaired motherboard and my repaired 6600GT from MSI. I put everything back together and I'm careful when I wire/reconnect things.
I was able to POST....blah blah, long story short. In the end, I couldn't get a signal to my monitor, even though the monitor was on with the status led on green (therefore receiving a signal).
I tried a lot of plugging and unplugging, took out everything except for my primary hard drive (all PCI cards, all kinds of drives eg: optical, floppy, etc).
It didn't help so I unseated my 2 sticks of ram and installed them each (1 stick only) in DIMM1 to single out bad ram. Neither one helped either. So I gave up and posted with no replies.
So at 3am, before going to sleep, I wasn't contempt at sending my suspected motherboard into RMA again after waiting a week to get it back. So I unplugged all my hard drives from the board. (unplug all sata and pata and any other interface). I then plugged one of my 4 non primary hard drives. This got my POST screen back up with a critical message and warning (CPU speed not set, etc etc). No biggie, I can fix it now.
I think you should try that (It's happened on my first dell back when I was a rookie too).
There's some kind of memory thing where you have to basically unplug all connections from harddrives from the motherboard and then reinsert the one you want to use. Hope this helps. Please let us know so that future readers can try the "solution." Thanks.
Best Wishes
-Wayne
Have you tried a different power supply yet? Also, I assume you've made sure the 4 pin connector on the motherboard is connected... Sometimes they have an 8-pin connector there (I'm not sure which your board has as I have a P5W-DH) and that has to be hooked up correctly.
Maybe the PSU, Antec's were having issues with Asus boards for a while. Do some searches on that. I'd have thought it was resolved by now though...
I got one of the first retail mobos and I got the CPU error too (early August) but I was able to post and update immediately. That RAM should be fine, that's what I have (you have C5 right, you'd probably have noted if it was the faster stuff).
Hello,
So I had this issue myself.
I was using OCZ rev 2 Platinum 6400 memory.
One thing I tried that worked was:
a.) clear the cmos
b.) while booting hold down delete on the keyboard
c.) if this doesn't work, unplug the power for 10 seconds, plug back in and hold down del.
d.) if this doesn't work, bang head against desk.
~Cktech :D
Thanks to everyone for the suggestions. I ended up sending it to Kentucky for ASUS to work on, so we'll see when it gets back here (hopefully next week!) and I'll post a follow-up if it's working, or if it isn't. Again, my thanks, and if it's still broken I'll try some of the suggestions from this thread.
