Just got my second set of dual channel that won't post. G.Skill 800 ZX was the first, Team Xtreem 667 3-3-3-8 was the second.DamTheMan said:I really don't see why the corsair wouldn't work? Ever type of ddr2 i've stuck in this motherboard even ecc seems to work just fine. Hynix, Elpida, Micron, Samsung, kingston, corsair.
Backslash said:Are you sure your memory (this one?) is the problem?
The people in the reviews don't seem to be having any compatibility issues with their P5B Deluxe. I have the same memory and motherboard (but no CPU yet), so your post is getting me worried.![]()
BIGmog My P5B Deluxe won't post when I put Corsair XMS2 6400 in either of the B slots. Both sticks work fine in A1 and A2 in single channel mode. But I can't run in dual channel mode if I can't use the B bank. I tried putting just one stick in B1 but it still won't post so I don't think it's an issue running in dual channel. The RAM works fine in the A slots so I'm pretty certain the mobo is bad.
Sufu said:I have the same prob on Corsair DDR800 TwinX Ram. I have two 1GB sticks, but the board won't post when I put them on the A slots! They only work on the B slots and only in single channel. Have the latest bios too (614), and everything else is working fine.
I tried chaging the DRAM freqency and timings manually, and bumping volt up to 2.1 for the ram...no go. It refuses to post with any memory in the A slots.
Megalomaniac said:I have Gskill F2-6400PHU2-2GBHZ running at 510 and i think 5-5-5-12
no problems...
