- Jun 3, 2003
In a short time I am going to be in posession of both an Asus P4P800 and an Abit IC7. The P4P800 was my first motherboard, but it fried (twice), so I gave up and bought an IC7. Then last week I decided to RMA the P4P800 (the CPU socket was in flames...I truly doubt that that was my fault).
One will be kept, the other paired up with a 2.4A and sold. So obviously if the P4P800 dies with a Prescott and the Abit doesn't care about the difference, then the Abit is the only choice. Or vice versa.
As I see it:
Pros of IC7:
875P chipset
Firewire
Cons of IC7:
No PAT w/ 4 DIMMs (my current situation)
No onboard LAN (currently using a card)
Pros of P4P800:
Onboard Gigabit Ethernet
Possibility of PAT w/4 DIMMs (haven't tried in a long time)
Cons of P4P800:
No firewire
PAT not a certainty
Possibility of it bursting into flames again
One more thing: the reason I was considering selling the P4P800 to this friend of mine is that it only fried when I was in the case doing something. (And yes, the power was off at the time.) It ran from June-August just fine until I was playing with my fans or something and then from August-March just dandy until I was cleaning up my wiring job. Therefore, logic dictates that if there is no fiddling, there will be a much lower chance of failure. Besides that, he'll be using a different processor, RAM, and case. I don't hear about any other users who have had P4P800s die on them quite so often so it's probably something in my setup that it doesn't like.
As I see it:
Pros of IC7:
875P chipset
Firewire
Cons of IC7:
Pros of P4P800:
Cons of P4P800:
No firewire
PAT not a certainty
