P4c800E Deluxe Sata ??'s
kennyc28
I have looked but I cant find any where if my motherboard supports the 3gb/s drives Does anyone know?
No, it's only SATA1 (not that it matters...you're not going to be able to get 300mb/s with current HDD technology anyway).
does the 16mb buffer make a noticeable difference? I am running out of space on my hd with all my pictures and movies and crap I was just wondering what to do with this mobo I am pretty happy with my setup
Yes, with 16mb cache, there is a big difference. I don't have any benchmarks to show you off the top of my head, but there's a difference.
That being said, I'm pretty sure a SATA2 drive will work in a SATA1 port. You can't use NCQ, but other than that, it's fine. Also I believe Maxtor makes some SATA1 w/16mb cache HDD's. I have a couple of those and they work fine.
