- Nov 2, 2004
Is there any way for me to measure the vcore with a multimeter?
I've noticed that my core voltage drops suddently (as much as .9volts) while the system is idling and I'm thinking it's the only reason my system reboots itself while booting windows at high OC settings.
I want to view my cpu voltage as the PC boots to see if that's the problem.
Cornelius, I saw you make a post about your old P4C800-E dropping voltage. Maybe you could shed some light on how you go about measuring the voltage directly with a multimeter?
