P45 (ICH10) and eSATA Hot Plug
Midaro77
From my research, I have learnt that eSATA on the previous Intel ICH9(R) southbridge was not implemented fully. That is, it wouldn't list eSATA drives under the "Safely Remove Hardware" icon, even when installed on Vista, with AHCI enabled in the BIOS and the Intel Matrix Storage drivers installed.
So people who wanted eSATA used the JMicron SATA ports on many motherboards--which worked correctly.
Now, P45 boards have just been released in Australia, and I've been looking at Gigabyte's offerings. Unfortunately, all of the affordable (ie <$200) Gigabyte P45 motherboards do NOT have the JMicron SATA controller (the P45-DSR5 does but it's $300+).
So what I want to know is: does the new ICH10 southbridge provide the "Safely Remove Hardware" icon? (I've heard rumours that it is just a die shrink :( ).
I know there are hacks to safely disconnect, and that you probably won't lose data if you just disconnect the drive when it's not being accessed, but I intend on using eSATA hot plug in a big way and would like the reassurance of it working correctly. ;)
I thought it did? (Shrug)
It worked like that on my nForce4 chipset with AHCI enabled. I don't have it enabled on my IP-35 Pro because of the JMicron controller, but Hot Swap or Drive Swap will fit the bill.
Good Luck!
