I've heard about people putting the mobile p4s into their desktop machines, and I finally took the plunge and got one. Well, Celeron actually, but it's a Northwood-based, 256k L2 variety. It's a 1.7Ghz, SL6J3.
I was hoping for some easy, drop-in lovin', but I figured it would take a little tweaking.
From what I gather, the problem is voltage. Mobile P4s use 1.3v, while desktops use about 1.5v. I took a look at the tech docs, and it looks like the difference is two pins. VID4 is high for 1.3v, and needs to be low. VID3 is low, and needs to be high. So what I'm guessing is clip VID4, and connect VID3 to VID2.
Luckily the board I have it on is actually a 423, with the little converter board, so I was thinking I would just clip the pins on the converter instead of on the CPU itself.
I'm just curious if anyone has actually done this pin-mod... and if it looks like I'm doing it correctly. Thanks!
