Voltage is around 1.55. Somtimes when i look it will be at 1.6.
Should i worry about this?
currecntly set at 1.525 in bios. I talked to intel about it being 1.6 for the minimum in bios after i first installed it, and they had me take my proccessor out and put it back in after doing a CMOS reset, this seemed to solve the problem.
The heatsink+fan intel supplies has changed(other 2.4 is from made July 03, this one is March 04). I now run 37*C CPU, 31*C mobo, where my other 2.4C never could get near 3ghz, and at stock speeds it would load at 45*C.
Current Room temp reads out @ 21*C(70F) and 48% humidity.
currently testing to go higher. (its on DDR400 ram so i'll have to jump down to 3:2, don't have $$ for new ram)
over all, i'm pretty happy w/ this OC. right now stock voltage for CPU and ram.
DDR400 running past DDR450 @ 2.65V.
